Need helping finding replacement parts for aluminum screen frames
kraftj | Posted in Construction Techniques on May 28, 2011 10:25am
My 20 year old money consuming house that I have been bringing out of a state of disrepair since I bought it needed the flooring of the screened in porch replaced.  The project has been going somewhat smoothly other than the fact that i found that the rubber/plastic strip that locked the framed 40″ X 7′ extruded aluminum screen panels together proved to be extremely effective.  The only way I was able to separate the panels was to cut this strip with a razor (both inside and outside).  I have done some looking around on the internet to find a source for a new locking spline when i go to put these panel back in but so far I have struck out.  Could you please look at the attached pictures and let me know if you know the manufacture of these aluminum extruded frames or a source for new locking splines.
  1. DanH | May 28, 2011 11:11pm | #1
    Have you checked with any local window glass places?  I've found that they frequently have such parts.
  2. calvin | May 29, 2011 07:14am | #2
    Good hardware's
    that do screen replacement have surprised me in having parts for many different triple track corner connectors.
    or, take a look at Blainehardware-online.
  3. kraftj | May 29, 2011 03:38pm | #3
    It appears to be around 5/8"
    It appears to be around 5/8" wide,  the outside which was exposed to sun was very brittle however the inside was much softer like rubber.  So i suspect it was a rubber spline.
