We’ve just been paid a friendly visit from OSHA and much to our dismay we were sited for not having a guard on our table saw. We would like to be as safe as possible and realize the dangers in removing the guard. However, there seem to be times when the factory guard is not a practical safety device for certain table saw operations and at times can be more dangerous than having no factory installed guard. So my question is; Is there a good resource for shop made guards that cover the wide spectrum of use that our table saws receive?
Looking for any advice. Thanks.
I retro-fitted some older Deltas with the Uniguard. It can be flipped up when making set ups easily. Loosening one knob will allow it to be removed. There is a long arm version for 50" fences. Does a good job of not interfering with the operation of the saw. Nice and solid.
Down side is no dust collection or anti-kick back. The front of the guard that closes the space between the two side pieces is weak and easy to break. Unless you have long arms, it is hard to remove and adjust from the front of the saw.
Is this for a shop saw, or a jobsite saw? Can't help on the latter....on the former, I have two saws with Biesemeyers, and one with an Excalibur, all for 50" fences (I think I saw that Excalibur has a newsplitter attachment too, that flips out of the way for dadoes etc., but I don't have that). Neither setup is perfect, but I'd choose the Excalibur over the Biesemeyer.....it can connect to dust collection, but most importantly it doesn't hang up on the material at the start of the cut the way the Biesemeyers do, and it just seems to be a smarter design.
I used to be macho, and down on blade guards, now I'm a believer (after having to do first aid on a student, and seeing other close calls).....my rule here is you absolutely have to try to do the operation with the guard in place.....if, and only if, you can't, then remove the guard and use whatever other options are available to make sure the operation is safe (featherboards, two pushsticks, etc.). Usually the only thing you can't do once you get used to the guards is ripping thin pieces....or dadoes if you have a splitter in your setup, but in some places you aren't allowed to do dadoes anyway.
If you want to be proactive, you could write out a simple safe work procedure/safety rules sheet to keep at the saw (I have them posted permanently at each saw), and make sure every employee gets trained on safe work, and signs off to that effect. Believe me, if you ever do have an accident, having procedures in place, and having your bases covered, goes a long way with OSHA.cabinetmaker/college woodworking instructor. Cape Breton, N.S
I realize that I should have been clearer on the type of saws we use. These are jobsite, portables such as Bosch and DeWalt. these guards make it impossible to make cuts even as wide as 1.25".
Its frustrating.
I once saw a guard that was suspended from the ceiling on a balance arm.
Don't know how well it worked, and don't remember any details. Just thought it looked interesting.
You pused the thing down when you needed it, then lifted it up out of the way when you didn't.
Life is not a problem to be solved, but a gift to enjoy.
MTG, here is a link to a shop made blade guard adn dust collector. It was from the old fourm Badger Pond that is now found on the Wood Central site. I hope this is what you are looking for.
Good Luck
Mike
http://www.woodcentral.com/bparticles/blade_guard.pdf
Guarding is required when ripping or cross cutting on a table saw, but when dadoing, grooving, or rabbeting, the spreader bar is not required (because these operations cannot be done with a spreader bar). But, the blade guard and anti-kickback pawls are required always.
Here's the exact language of the regulation. A table saw is both a "hand-fed ripsaw" and a "hand-fed crosscut table saw".
Shop made guards are permitted, so long as they meet the regulations above.
I think you were "cited", not "sited".
I have the 50" uniguard on my unisaw and am pretty happy with it. It comes with a separate splitter with anti-kickback fingers that is easy to remove and replace.
