Need mini-bar joist
FastEddie | Posted in General Discussion on April 16, 2006 07:51am
Finishing out a condo that has 11 ft from floor to underside of floor above (all concrete).  HO wants a “floating cloud” over the dinign table.  Think of a sheetrock ceiling panel about 4 ft x 10 ft x 4-5 inches thick, suspended about 9 ft over the table.
One thought is to frame it with metal studs like a wall section, and rock top, bottom, and all edges.  Then hang it from stainless cables.
Secoind thought is to use mini bar joists, maybe 16″ oc x 10 ft long, screw a sheet of 3/4 ply to the underside, then hat channel, then sheetrock.  Same idea as option 1, but a little more industrial.
Am I right in thinking that stage crews use small scale bar joists to hang the lighting and scene backdrops?  I’m hoping for something that might be in chrome or stainless finish.
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.”  T. Roosevelt
  1. Frankie | Apr 16, 2006 08:22pm | #1
    MDF or Plywood. 4' x 10' x 3/4" sheets
    1" x 4" plywood strips glued on edge on panel top for stiffening.
    Threaded rod from ceiling aligned with threaded rod from panel. Turn buckle used to level.
    Supports are far enough away from edge so as not to be visable from 12' away.
    Option 2 (From underside to ceiling):
    GWB, 3 1/2" metal studs (on edge), 4x8x 3/4 plywood, threaded rod as noted above.
    Frankie
    There he goes—one of God's own prototypes—a high powered mutant of some kind never even considered for mass production. Too weird to live and too rare to die.
    —Hunter S. Thompson
    from Fear And Loathing In Las Vegas
