I’ve started working on a Chinese Checker Board. I have it drawn out. with the following measurements. From point to point, it is 15 inches. Each triangle is 5″ on each side. There are 10 marble holes in each triangle. There are 13 holes from point to point on the longest line. There is a total of 121 holes in the board. Problem: I don’t know how to measure the distance between the holes, and it’s driving me crazy!! Thanks for whatever help anyone can give me.
![](https://images.finehomebuilding.com/app/uploads/2024/07/16103615/01232548-cost-of-building-house-feature-thumb-16x9.jpg)
Understand the difference between estimating and cost planning, and don't let your sweat equity evaporate into budgeting mistakes.
These two pages should give you a few ideas. Scroll to the bottom of the first link to see some relevant choices.
http://www.veritastools.com/Products/ProductList.aspx?cat=42
or
http://www.pearlpaint.com/shop~ocID~1999~parentID~1999~categoryID~1951.htm
Thanks, I'll check into it. Bert
Along each edge draw lines at x distance from the side paralel to the side and repeat. Each line will be x+x and the x+x+x and so on. Where the lines intesect is where to hole goes.
"It is what it is."
Thank you kindly, Mike.
