Need stripper advice from the North East
McDesign | Posted in Construction Techniques on February 15, 2007 02:03am
Hey – I know you guys traditionally strip ceilings before DW.  I’ve never done it, but have had to here to create a strong flat plane.
Okay, but I have some questions about corners.  I made them up to a string line, so they are a straight “V”,
BUT – On inside corners, do I butt them, which leaves the DW unsupported between the 16″ OC 1×4, like this –
 Or weave them long, which means at least one side is supported every 8″, like this –
And also, on exterior corners, how do you create them?  This is woven long, marked, and sliced with a Sawzall, but will it need anything more than the plastic corner tape?
Thanks, you NorthEast strippers!
Forrest – not a stripper
Edited 2/14/2007 6:04 pm by McDesign
Edited 2/14/2007 6:05 pm by McDesign
Edited 2/14/2007 6:06 pm by McDesign
  1. oake226 | Feb 15, 2007 02:17am | #1
    I butt them together then use additional blocks in the corners to keep the edge true.
    On outside I run one side long, then butt the other side to the inside face and snap a chalk line. Figure out the angle on your saw and your done
  2. MikeSmith | Feb 15, 2007 02:17am | #2
    i'll "stripper " you..
     it's  "strapping" or " furring", dammit
    here in RI it would be "furring"
    inside corners are pretty much what you've done
    outside corners we will often  use 1x6 instead of the usual 1x3
    and we will build a corner.. i do this because  the framing behind the strapping likes to move with the seasonal changes of humidity... especially in corners
    but  if both pieces of the gypsum are fastened to the same sub-base ( the  1x6  corner strapping )  then they are not going to move
    ..... of course the same can happen on an inside corner .. so if you think that's a possibility.. then make a cub-base corner there too..
    as you have by now found out.. that 3/4"  plane you get with furring makes a lot of things possible that are harder to do with framing
    like light bases.... or fan supports.. you can easily slip in a piece of 3/4 ply anywhere in your 3/4 furring plane
    i think you're gonna like furring your ceilings.... it's so... so......
    .........civilized
    Edited 2/14/2007 6:55 pm ET by MikeSmith
      McDesign | Feb 15, 2007 02:25am | #4
      <inside corners are pretty much what you've done>
      Yeah, but which side?  Woven or butted?  Are both okay?
      Thanks for the real STRAPPER input -
    2. criddle | Feb 15, 2007 03:20am | #8
      I saw the pic you posted and realized you have the same issue I am facing.  The preform shower only goes so high.  The shower head comes out above that.  How are you going to address that space between the top of the surround and the ceiling?  I've got a client that bought a really cheap (1/8" plastic sheet) surround and I am wondering if I should be buying a full ceiling height sheet for moisture problems.  I've got green board behind, so there is something to start with.
      1. MikeSmith | Feb 15, 2007 03:51am | #9
        criddle.... all of our tub & shower surrounds  are topped by blueboard & skim-coat plaster
        we set our exhaust fan/lights so they are  right on the edge of the shower /tub
        and we use a nice enamel paint.. no problems with  the gypsum
        if you were concerned , you could use  Durock in those areas and skim-coat with Durabond and finish with joint compound
        but generally speaking  green board should do fine .. just leave a caulk space at the bottom so you don't wind up wicking moisture from the flangeMike Smith Rhode Island : Design / Build / Repair / Restore
        1. criddle | Feb 15, 2007 04:13am | #10
          I guess I was just being too much of a worry wart being around water.  Thanks, it simplifies my life!
            BossHog | Feb 15, 2007 04:18am | #11
            The best advice I can give you is:NEVER date strippers.
            Strippers: For men who are too financially solvent
          2. dovetail97128 | Feb 15, 2007 05:59am | #12
            But are they OK to rent when you need one?
  3. dovetail97128 | Feb 15, 2007 02:20am | #3
    Forrest,
    FWIW
    I ain't from the N.E. But from the N.W. so what I have done is probably not what the builders there would do.
    What you are doing is uncommon here (the strapping) but I have had to do it in several old house remodels.
    On both inside and outside corners I snapped a line 3 1/2"-4" back from the point of intersection on the horizontal strapping . Then held a 1 x 4 up to what is either the hip or ridge and marked where the strapping would hit it. After marking it I glued and stapled 1x blocks to the back side that were long enough to allow me to fasten thru the strapping into the blocking.(can also be done with offset 1x stock , anything that gives a surface to fasten thru the strapping into the "hip/ridge" piece)
    I got a continuous nailer that way right at the corner. Nothing floats , lots of fastener area for the drywaller.
  4. highfigh | Feb 15, 2007 02:28am | #5
    Where's the pole?
    If you're gonna title threads that way, ya gotta be ready for disappointed people to ask questions.
    1. MikeSmith | Feb 15, 2007 02:56am | #6
      forrest... here's an example of an outside corner
        McDesign | Feb 15, 2007 03:06am | #7
        Ah.  Nice.
        I'm going to do the "Mooney Wall" thing, too.  See how the insulator likes it with JM Spider.
      2. PatchogPhil | Feb 15, 2007 06:11am | #13
        Mike,
        Is that.... <gulp> ........  fiber.... glass..... behind the tub surround?  On your job site?  <G>
        Phil
        1. MikeSmith | Feb 15, 2007 06:28am | #14
          phil.. john harkins asked me the same question 3 years ago
          http://forums.taunton.com/tp-breaktime/messages?msg=39120.17Mike Smith Rhode Island : Design / Build / Repair / Restore
          1. PatchogPhil | Feb 15, 2007 06:37am | #15
            Were you tempted to rub some cells on it or spray paint it grey?
Versatile Vise
