Neoprene vs. Brush Door Sweep
tommyreno | Posted in Construction Techniques on October 10, 2006 12:41pm
Under what circumstances would one use a:
— neoprene door sweep?
— brush door sweep?
Which one is more often used on a swinging door over a concrete floor?
Thanks.
  1. doorboy | Oct 10, 2006 12:59am | #1
    If there's a threshold under the door opening, I would use the neoprene door bottom. If it's barely clearing the concrete floor, I would use the brush type for its greater flexibility. Keep in mind that the brush type is inferior to the neoprene as far as weatherproofing and critterproofing.
    "Kinky for Gov. of Texas"
  2. DanH | Oct 10, 2006 01:10am | #2
    The brush doesn't seal as well in ideal circumstances, but will tolerate more irregularity and misalignment -- will seal reasonably well where the neoprene seal would either show a gap or wear/tear out rapidly.
    1. tommyreno | Oct 10, 2006 02:06am | #3
      Thanks for the replies.
      The door is actually two of them -- both 4' wide doors that are an entrance to a garage with a concrete floor. There is no threshold, just the floor, which is smooth concrete, save for a crack or two. There is a crown in the floor, so the gap to close is about a 1/2 an inch at the center where the doors meet and between 3/4" and 1 1/4" at either end where the jambs are. Where it swings out the driveway slopes down.
      I'm leaning toward neoprene, primarily for the ability to keep out the rain.
      How much longer should the neoprene be than the gap it is closing?
      Thanks again.
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
