I haven’t found the correct thread, so I created a new one :). Finally, I want to install air conditioning in my apartment so I’m looking for a suitable brand :). What conditioner do you recommend? Is the air conditioner Thermozone® ADA would be ok? Below the description:
built-in switch; high / low speed,
corrosion proof housing made ​​of hot zinc-plate and powder enamelled steel panels, color: RAL 9016,
Compact and easily positioned,
easy installation with cable and plug, cable length: 1.8 m.
(Source: http://www.centrumklima.co.uk)
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
This is 99% a US board (not counting the spam), so most of us would not know anything about air conditioners in the UK. (In fact, do you even need air conditioners in the UK?)
I have a similar
That looks like it is an "air
That looks like it is an "air curtain" machine, not a room A/C.
What do you want to accomplish with it?
I would like to know more about this air conditioner. Thank you so much for the updates.
