New bath on existing 2nd floor
Tharrett | Posted in Construction Techniques on August 21, 2007 03:04am
In the planning stages of a new bath above finished space.  Toilet & shower will be back to back with existing bath to share the “wet” wall.  The sink will be on the far side if the bath.  I will need to run the sink drain about 8′ across (through) the existing floor joists.  Based on the span, sizing & loading, I can bore ~2″ dia holes in the floor joists.  Notching is not an option.  So here is the question:  Is it customary to cut the 8′ long sink drain pipe into small lengths to fit them in and end up with a several glued connections or is there some other resonable technique to getting the drain pipe in?
  1. MikeHennessy | Aug 21, 2007 03:24pm | #1
    Yep. A bunch of sections. Just don't get careless with the glue.
    Mike Hennessy
    Pittsburgh, PA
