New energycode requires R-5 on the outside
weekendwarriorben | Posted in Energy, Heating & Insulation on November 15, 2010 11:24am
The new Washington State Energy Code (WSEC) is going into effect and our architectural firm is in the process of updating our details. We design a fair amount of resort homes on the East slope of the Cascade Mountains, 70 miles east of Seattle, in climate zone 2. This area is not as wet as Seattle, but can get several of feet of snow, with below freezing temps, while the summers are in the 70’s and 80’s.  One of the WSEC requirements is to apply R5 foam between the wall sheating and the siding, to act as a thermal break.
We are wondering about the order of assembly.  Logic tells me the following (from inside out): gwb, 2×6 studs with R21 batts, 1/2″ structural sheating, 1″ foam, 60 minute paper, siding. The siding is usually cedar board&batt,  horizontal bevel, or shingle ( it seems odd to be installing the latter thru the foam though). At the windows and doors we could show a 5/4 nailer for the nailing flange; at the bottom of the wall also a 5/4  strip, to cover the edge of the foam.
One builder suggested adding an airspace between the paper and the siding and installing the siding over 3/8″ or 1/2″ strips, as a rain screen application. Add a CorVent type product top and bottom between the strips (assuming they run vertical; not sure what we’d do with vertical or shingle siding; we need to keep the vertical drainage channels, so add another layer of strips going the other way, or sheating?).
Part of my concern is how much the siding starts hanging away from the foundation wall with all these layers. It gets trickier if the clients wants thinset stone in places (here we’d be adding another layer of sheating, metal lath, etc). In that case I’d be inclined to create a foundation ledge by placing the mudsill to the inside of the stemwall.
I saw similar subjects discussed in this forum, but not this particular one. So ideas and suggestions are welcome.
Ben
  1. Clewless1 | Nov 16, 2010 12:26am | #1
    About 15 years ago, a colleague of mine in Spokane would delete the OSB sheathing and replace it w/ a diagonal brace let into the studs. He replaced it with 1/2 or 1" polyiso. He said that finding a stud was relatively easy ... just poke a hole through the insulation to see if the stud was there. Now literally, this isn't practical/good, but the point is well taken and it would be easy to mark your studs for siding applications. This makes a wall not much thicker than normal ... but w/ R-5 or 1", you may still have some issues here and there. Diagonal bracing still meets structural codes and is inexpensive; and not that difficult labor wise.
    Jeff_Clarke | Nov 16, 2010 12:38am | #2
    http://www.greenbuildingadvisor.com/book/export/html/17157
    http://www.buildingscience.com/documents/guides-and-manuals/irc-faqs/irc-faq-cladding-attachment-over-insulating-sheathing/?searchterm=foam
  3. rdesigns | Nov 16, 2010 12:45pm | #3
    Below is Table 5-1 of the WSEC
    The table shows walls (climate zone 2)  required to have a U-value of .056, which converts to about R-18.
    So, I'm wondering if R-5 on the outside is really needed, or is there some other part of the code I'm missing?
    TARGET COMPONENT VALUES FOR SINGLE-FAMILY RESIDENTIAL
    Climate Zone
    Component
    1
    2
    Glazing % Floor Area
    15%
    15%
    Vertical Glazing U-Factor
    U = 0.30
    U = 0.30
    Overhead Glazing U-Factor
    U = 0.50
    U = 0.50
    Doors
    U = 0.200
    U = 0.200
    Ceilings
    U = 0.027
    U = 0.027
    Walls
    U = 0.056
    U = 0.056
    Floors
    U = 0.029
    U = 0.029
    Slab on Grade
    F = 0.36
    F = 0.36
    Below Grade
    Wall R-Value
    R-21
    R-21
    2' Depth: Walls
         Slab
    U = 0.042
    F = 0.59
    U = 0.042
    F = 0.59
    3.5' Depth: Walls
         Slab
    U = 0.041
    F = 0.64
    U = 0.041
    F = 0.64
    7' Depth: Walls
         Slab
    U = 0.037
    F = 0.57
    U = 0.037
    F = 0.57
    1. davidmeiland | Nov 16, 2010 03:35pm | #5
      Are you looking at
      the 2009 code? There are indeed some scenarios in which R21+R5 would be required for exterior walls in zone 2. Whether you need to accomplish that with exterior foam or some other means... not sure. This takes effect 1/1/2011.
      1. rdesigns | Nov 16, 2010 04:15pm | #6
        I'm pretty sure
        it is the '09 code, listed to become effective beginning Oct. 29, 2010.
        http://apps.leg.wa.gov/wac/default.aspx?cite=51-11-0502
        Also, the WSEC specifically allows trade-offs in any of envelope elements so long as the net u-value for the sum of the components ends up being equal to the prescriptive path.
        EDIT: when you open the link, be sure to scroll down to the section that becomes effective Oct. 29, 2010--the top section was effective only up till Oct. 29.
        1. davidmeiland | Nov 16, 2010 06:54pm | #7
          I attended a training
          yesterday put on by WSU Extension Energy program, and they covered the various paths to approval. Just grabbed the notes, and I was mistaken about what I wrote above. In Zone 2, there are three prescriptive paths based on percentage of glazing. At glazing = 12% or less, your wall requirement is R-21 intermediate framing, which basically means 16" O.C. with insulated headers @ R-10. Above that and your wall requirement is R-19 + R-5, although I'm not sure if that means that continuous exterior foam is required, or if you could satisfy the requirement with R24 or better in the stud cavity. I tend to think not but since I'm in Zone 1 I didn't ask. I can email you their PPT slides if you want, they are pretty good, and very good when combined with the Gary & Luke lecture.
          1. rdesigns | Nov 17, 2010 09:26am | #8
            It appears that Washington has modified the the IECC to allow a little more flexibility in prescriptive paths, so it's a good idea for designers to get familiar with various options available to them. Do you know if the WA code works with DOE's REScheck program?
          2. davidmeiland | Nov 17, 2010 05:48pm | #9
            Dunno about that
            but the folks at WSU will. (360) 956-2042
          3. MikeSmith | Nov 17, 2010 10:21pm | #10
            pulled a permit today
            RI  is  2009 now too... my BI  told me  i can use       res check      for conformance
            ran some preliminary   numbers.....looks good
          4. weekendwarriorben | Nov 18, 2010 10:52am | #11
            R5 over the framing
            I have attended the same WSU program, earlier this year and we talked about the climate zone 2 wall insulation requirements. The exterior insulation is specifically meant as a thermal break, rather than beefing up the R value between the studs. I thought about putting the foam between the studs and the sheating, but that poses challenges in getting the lateral design to work.
  4. DaveRicheson | Nov 16, 2010 03:08pm | #4
    Thinset stone may be applied over paper and metal lath attached directly to the foam board. At least accordind to the El darado seminar I attended a few years ago. just use long enough nails to pentrate through the foam  and sheathing to the studs.
