New Faucet Problems
Tomknixx | Posted in General Discussion on January 19, 2007 06:21am
I recently installed two new faucets in my home. The bathroom one works fine. The kitchen now has a squeal when it is turned on anything more than 1/2. Also, there is a “pounding” when it is open full or when I am switching from hot to cold. It seems like there is something wrong with the valve inside. I have tried turning the water valves down thinking the pressure was too high but this has done nothing. The faucet was new (Delta) and I was wondering if there is something I need to do before taking it back.
Tom
  1. rez | Jan 20, 2007 09:30pm | #1
    Greetings Tom,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
  2. plumbbill | Jan 20, 2007 09:55pm | #2
    Single handle or double handle?
    If it's a double handle, then shut off angle stops.
    Remove cartrige from the noisy side.
    Look for the washer to be loose, usually a screw holding washer in place.
    That being loose is a common culprit of a noisy faucet.
    “How many observe Christ’s birthday! How few, his precepts! O! ‘tis easier to keep Holidays than Commandments.” —Benjamin Franklin
