New framing around furred door
jharvey8891 | Posted in Construction Techniques on January 24, 2021 09:08pm
I have a back door that was in a brick exterior wall. The wall originally had furring strips, and I’ve switched them out with 2×4. My problem is that now the door will be inset into the new wall. Is there a way to frame this out with out just moving the door out  towards the new wall?
  1. calvin | Jan 24, 2021 09:59pm | #1
    You either live with it and add jamb extensions or reset the jamb. The current inset will only allow 90 degree of opening. Also, unless there’s more room on the latch side the latch will scrape that extension in use.
    1. deftandlevel | Jan 25, 2021 12:12am | #2
      You could try some deep/wide throw hinges if you want the door to open more than 90 degrees.
      1. calvin | Jan 25, 2021 07:13am | #3
        Thanks!
        Been so long since I dealt with extra thick casings I didn’t even remember those.
    unclemike42 | Jan 25, 2021 10:40am | #4
    https://www.hardwaresource.com/steel-wide-throw-butt-hinge.html
    Something like this?
  3. deftandlevel | Jan 25, 2021 11:19am | #5
    Those are what I was thinking UncleMike. The strike hitting the extension jamb might still be an issue with the hinges but maybe a slight bevel on the extension jamb could avoid it.
      unclemike42 | Jan 25, 2021 03:40pm | #6
      Might be a good idea in this case to make the extension thinner than the existing door jamb. Looks like the existing door is flush with the inside end of the jamb.
      Could even run drywall to the edge and finish with some J channel something like what I did in my basement. My case was to a replacement sliding glass door, but the geometry could work. It all depends on how thick the door jamb is, and how close the new studs are.
      In my case, I added two inches of foam and more furring to existing furring into a block/brick exterior wall.
Mortar for Old Masonry
