New gable roof addition. Please help.
Aspa | Posted in General Discussion on May 22, 2013 04:47am
Hi, I would greatly appreciate any advice! I want to rip off this flat leaking porch from the 1950s and add a gable roof with a 7/12 pitch. But I’m having trouble visualizing how the new gable roof would attach to the existing roof on both sides so I don’t have a flat valley, where water doesn’t drain.  The dimensions are 10ft X14ft. Thank you.
  1. oops | May 22, 2013 05:51pm | #1
    Why 7/12 pitch roof?  The roof in the pics don't look that steep.  You can do what you suggest, but  you will have to deal with the water in the valley, created by the added gable roof,  with a cricket.  The cricket will be like a low pitch roof.  There might be other options, but would envolve major framing changes.  At least that is my take on it.
  2. DanH | May 22, 2013 08:40pm | #2
    Good luck! :)
  3. nycarpenter | May 22, 2013 09:54pm | #3
    How about replacing the leaking roof?  Or try sketchup to see what can be done.  After playing with the design the flat roof might look really good!
    1. Aspa | May 22, 2013 10:23pm | #4
      Thanks for replying. I've been using woodcraft, a 3D auto cad program on the iPad. The gable roof aesthetically looks the best. I'm also going to be building a deck over the existing concrete porch, which is easy. So there might be a lack of headroom if I replace the roof. Maybe I could install a small cricket roof along side of the gable roof to promote water drainage?
  4. DanH | May 22, 2013 11:10pm | #5
    The only thing I can think of is to make a low-pitch prow-front gable on a 45.  The valleys would still be problematic, though.
    1. DanH | May 22, 2013 11:19pm | #6
      Right side up.
      1. Aspa | May 24, 2013 10:40pm | #10
        Thank you!
  5. florida | May 23, 2013 07:30am | #7
    You've got a problem if you want a gable. It could be done but you'd need to modify both of the existing gables to make it work. Your new gable will have to butt into one of the roof pitches that are already there. If the new roof is higher than the old roof the far side of the old roof will have to be exteneded to the ridge of the new roof. No big problem there. But you're still left with the parallel  gable. Leaving a blind valley between them is a terrible idea so the only thing left is to raise the ridge of the new gable to a point in the same plane as the existing gable. The opposite side of the roof would then extend in a flat line to your new ridge.
    Unless your budget is unlimited I think this is out of the question. If it were my house I'd put down a good roof material and call it a day. You could get more pitch by extending the back of the flat roof up the adjacent pitches several feet. Still a lot of framing but you'll get the water off the roof very quickly.
    1. sapwood | May 23, 2013 11:44am | #8
      Ditto
      We have a remotely similar situation on our house. Rather than do extensive framing to create a pitched and more attractive roof, we opted to be practicle. So, during a whole house re-roofing, we had a pvc membrane installed over the flat roof. The guys ran it well up under the adjoining shingles. No leaks and no worries. The roof is still not very attractive so we simply divert our eyes.
    2. Aspa | May 24, 2013 08:00pm | #9
      Good points!
      Thank you for the advice. I will rip off the old porch because of rot and create a new overhang like you suggested by extending the back of the new roof several feet. But the two intersecting roofs are different pitches. 7/12 and 5/12. Would I lay out the rafters like I would when building a gable roof?
      1. florida | May 25, 2013 10:34am | #11
        You'd going to raise one end of your shed roof by extending it up the slope several feet. nail down a 2 X 12 at the high point and nail your raftewrs to that. The cut will be the reciprocal of the pitch. so it will be a long cut. Lay the rafters out just like you would on any roof and get as close to the other roof as possible. At the point use a straight edge at the top and the botttom to extend the shed roof line to the other roof, Run a string between those points, measure down to the roof and cut your last rafter to that measurement.
        1. Aspa | May 25, 2013 08:04pm | #12
          I'm getting there!
          Thanks for all the advice. I did some demolition today and found the 2x4 rafters, 2x10 beams are relatively still in good condition. I jacked up the porch roof about 5-6 inches, because the foundation has settled. Everything is plumb now. The roof sheathing is 1x6's, with some rot in a few places (along gutters, and at intersecting gables). So I'm probably going to replace all the sheathing with OSB or Plywood. There is a felt or rubber type material that is on the roof. With a low pitch roof, what is the appropriate roofing material and flashing that you recommend? Thank you, and have a happy Memorial Day weekend
          1. florida | May 25, 2013 09:11pm | #13
            Take off the shingles up about 24 inches on borth sides so you can run whatever membrane you use up at least that far. if you have heavy snow I would go even higher. There are lots of peel and seal membranes that are easy to work with since they come in short rolls. Roll them out across the roof and continue across the valley when you get that high. At the botom corner put a kickout flashing to divert water away from the house. I'd also use drip edge on both outside edges. Roll out a base layer than a top layer. Once they are down run your shingles back down to the original position.
            You can also use EDPM, probably what you have now, but it's not a one man job and is much harder to lay then the self sealing membranes.
          2. Aspa | May 26, 2013 06:05pm | #20
            4/12 pitch?
            Could I add a 4/12 pitch to the top of the existing porch roof? That way I can shingle it and not worry about leaking.  How would I find the cut of the new rafters that attach to the 7/12 and 5/12 existing roofs and porch? Thanks
          3. florida | May 26, 2013 09:53pm | #23
            Sure. Your rafters will only butt to one of the two pitches and run parallel to the other. Running up the 7/12 will give you the shorter rafters but it won't matter. The big chice inmy opinion would be the appearance. As a matter of fact you could run your rafters all the way to the ridge and your porch roof would then appear to be part of the original roof.
          4. Aspa | May 26, 2013 11:18pm | #24
            Rafter cut angle?
            Never thought about running rafters all the way up, those would be some long ones. Good idea! Sorry for asking all these questions, but how exactly would I find the angle of cut for the head of the new rafter with a 4 or 5:12 pitch? I know it would be a long one, like you said before.  I was never good at math but I do have a CM pro Calculator.  Thanks again.
          5. florida | May 27, 2013 08:14am | #27
            I hate to admit it but I'd probably use trial and error on a cut like that. You could also put a knee wall somewhere in the middle for additional support and to allow smaller rafters. I think I'd turn the roof and run the rafters up to the lower ridge which will give you a new valley higher up the 7/12 roof.
          6. Aspa | May 28, 2013 07:16pm | #31
            Birds mouth?
            Instead of trying to figure out the long cut. Couldn't I cut some of the sheathing back on the existing roof and tie my new rafters into the old rafters of the house and build a knee wall? My new rafters are 16ft long. I want to match the eave of the new roof to the old, which is 6"3/4. I'm having problems laying out the birds mouth. The new rafters will sit on 2 2x10s. I think my pitch will be 2/12. Still a lot better than 3/4"/12. Thank you
          7. florida | May 31, 2013 05:11pm | #33
            You can get away with anything the building inspectors won't see but my engineer always has us nail a 2 X 12" to the roof for the rafters to sit on. With a pitch that low I wouldn't worry about a birds mouth especially if you're going to clip the rafters to the plate. But why not go up some more and get up enough that you can use shingles?
  6. DanH | May 25, 2013 09:54pm | #14
    I have no idea how to milk a 3-D rendering out of SketchUp, so here is a plan view of the "prow front" idea I mentioned earlier.
    Basically you have the two intersecting rooflines, and coming off from near the intersection of the two ridges is the ridge of the porch, running at about 45 degrees.  The porch ridge maintains an even height for its full distance, and two valleys are formed where the porch roof slope intersects the slope of the main roofs -- these are the two not-quite-45-degree lines.
    With a timbered treatment of the trusses supporting the "prow", this would produce a striking architectural feature.  Even with a simple clap siding "gable" I think the appearance would be pretty good.
    (But someone really needs to produce a 3-D rendering of some sort to reasonably judge the appearance.)
      MarkH | May 26, 2013 07:50am | #15
      I think it would look better if the ridge of the porch roof intersects the existing valley, but it may not if the porch roof becomes too asymetrical.
      1. DanH | May 26, 2013 08:29am | #16
        Yeah, I don't know how the fine points would work out best.  You'd almost have to build a scale model.
    2. Aspa | May 26, 2013 12:31pm | #17
      I think I might take the easy way out...
      Could i add a 4/12 pitch on top of the existing structure? That way I could shingle the new roof. How would I cut the new rafters to sit on the 7:12 and 5:12 existing gables and old porch? Thank you.
  7. DanH | May 26, 2013 02:50pm | #18
    Your first sketch made it a hip of sorts.  I had in mind a gable end, with the ridge running horizontal.
      MarkH | May 26, 2013 05:59pm | #19
      Well, I'm not sure what the OP wants or even has.  It was good practice for me with Sketchup.  I'm not good with it at all, and I have poor spatial imagination to boot.
      MarkH | May 26, 2013 06:19pm | #21
      uhhh this maybe?
      File format
      1. DanH | May 26, 2013 08:16pm | #22
        I appreciate the effort, but not what I had in mind.  Basically, take your first (no number) design but raise the ridge up so it runs horizontal vs sloping down.  Something like this (only the area under the porch roof would be open).
        File format
          MarkH | May 27, 2013 06:48am | #25
          That's pretty cool looking, but sort of odd.  I'm thinking the OP wants a steeper gable.  I don't see a clean way to do that.  I wish I could find a free way to make 3d pdf files.  I don't know if the OP has looked at the drawings.  At least you posted a thumbnail to preview.
          1. DanH | May 27, 2013 08:02am | #26
            Imagine the gable with open timbered trusses.
            MarkH | May 27, 2013 09:39am | #28
            I'm not too good at imagining,.  It wouldn't be good at protecting from rain and snow unless it was closed in behind the timbers.  I'm not a big fan of timbers anyway myself, unless they are on a big lodge, or on a very rustic style building.
          3. DanH | May 27, 2013 04:09pm | #29
            Doesn't have to be timbers, of course.  Could be a clap gable, or you could make it a hair decorative with diagonal claps.
            MarkH | May 27, 2013 04:46pm | #30
            I would just keep the existing look, I don't think it looks bad.  Maybe use a copper flat roof, or epdm. Oh well, it's fun to play with sketchup, but I never have made a nice drawing with it.
  8. User avater
    Mike_Mahan | May 30, 2013 09:30pm | #32
    The gable would look like this.
    Although it doesn't show an intersection with existing gables, the gable of the addition would look like this.
