new job
mikeroop | Posted in Photo Gallery on December 9, 2008 05:52am
started this a cfew weeks ago thought some of you might like you see it. as you can tell i’m not quite in the hang of stopping and taking pics
  1. JoshRountree | Dec 09, 2008 05:57am | #1
    Looks awesome, can you give anymore details?
    1. mikeroop | Dec 09, 2008 05:59am | #2
      Sure Josh what would you like to know?
  2. davidmeiland | Dec 09, 2008 06:11am | #3
    Are you running an I joist as your rim? Hard to tell but it looks like it in the first pic.
    1. mikeroop | Dec 09, 2008 06:14am | #4
      Dave we normally do on the rims that run parallel to the joist. I really hate I joist though.
      1. davidmeiland | Dec 09, 2008 06:22am | #5
        Never seen that out here. It's always rim board on top of the foundation or any exterior wall @ second story.
      BossHog | Dec 09, 2008 05:30pm | #7
      "Are you running an I joist as your rim?"
      Most manufacturers I've dealt with allow it under certain circumstances. There's a max PLF load, and you can't have any concentrated loads.
      In general, I think it's a bad idea. If you ever want to bolt a ledger board for a deck on there, you don't have anything to bolt to.
      Why does an OB-GYN leave the room when you get undressed if they are going to look up there anyway?
      1. ANDYSZ2 | Dec 09, 2008 06:18pm | #8
        So wouldn't header legs be a concentrated load and I thought any wall setting on them required webbing filled or 2x stock an !/8" longer to take the load off the Ijoists or in this case a rim joist.I believe the concern was the webbing knifing the top and bottom parts.
        REMODELER/PUNCHOUT SPECIALIST
          BossHog | Dec 09, 2008 06:34pm | #9
          "So wouldn't header legs be a concentrated load..."
          Probably not unless you had a wide opening with a lot of weight on the header.
          "...I thought any wall setting on them required webbing filled or 2x stock an !/8" longer to take the load off the I-joists.."
          You're thinking of where I-joists cross a load bearing interior wall where there's a wall that stacks above it.
          The merit of our Constitution was, not that it promotes democracy, but checks it [Horatio Seymour]
          1. ANDYSZ2 | Dec 09, 2008 06:41pm | #10
            Yeah but isn't that the same thing as using an I joist for a rim joist.
            It has a load bearing wall stacked on top of it
            The rim joist are an 1/8" taller to keep the load off the I joists.
            BossHog | Dec 09, 2008 06:46pm | #11
            No, it's completely different. A bearing wall stacked over a perpendicular I-joists puts a lot of load at one point.An I-joist used as a rim board has a (more or less) uniform load all across it.
            Kids in the front seat cause accidents; accidents in the backseat cause kids.
          3. ANDYSZ2 | Dec 09, 2008 07:04pm | #12
            I get it.
            I built an I joist second floor system this summer and was shocked at the 70+ page set of instructions and rules.
            I backfilled the webbing with 3/4" plywood both sides everywhere plumbing drain lines ran thru and added 2x material on both sides of each I joist  where they sat on my steel I beam for a future wall .
            I personnally wanted to use web joists but there was a 2200$ difference in price.But by the time I added up all the extra labor and beams and inconvenience the web joists make alot more sense to me.
      2. mikeroop | Dec 10, 2008 01:32am | #14
        yea we use band and fill in the web when necessary and we always use crush blocks under any load bearing points so all is good:)
    davidhawks | Dec 09, 2008 07:03am | #6
    Nice sized project to have this time of year and in this economy.  Congrats.
    Like Dave M, I've never seen I-joist used as band material, but don't see how it would be problematic.  (I'm sure someone here will though <G>).
    Is that a hip set truss kit or did y'all cut it?
    BTW, nice work--clean job.
    The best reward for a job well done is the opportunity to do another.
    Edited 12/8/2008 11:03 pm ET by davidhawks
    1. mikeroop | Dec 10, 2008 01:29am | #13
      99% of our roofs are stick built as was this one the hips were 32ft 12" LVL's with 2x8 rafters go figure my brother drove around behind the job when i had the roof ttotally ready for sheeting and came back and said you need to get down and take a picture of that it looks way cool but i didn't maybe i can get one from the attic for ya
      1. frammer52 | Dec 10, 2008 01:36am | #15
        Love the picts!!!!!!!!!!!!!
        1. mikeroop | Dec 10, 2008 04:49am | #16
          Thank for looking.
