new windows into existing wall
| Posted in General Discussion on October 19, 1999 06:17am
Hey gang I have to install quarter round windows that are used for new construction(with the flange)on either side of a chimmney. The house has vinyl siding(cannot remove)and finished drywall and wallpaper on the inside.
How can I insert the window?
Remove the flange?
Cut the siding?
Weatherproof it?
Thank you
Carl
  1. Guest_ | Oct 15, 1999 06:34am | #1
    I would pull the courses of siding invloved A install it with the nail fins. If the customer refuses to let you re hang the siding, walk away. It isn't worth the risk invloved in cutting the siding & hoping the J channel will cover the cut edges.
  2. olmsted_carpenter | Oct 15, 1999 03:39pm | #2
    Thank you Rob, but I am not real sure how to get the siding down in the area affected. I have put it up but never had to take it down.
    How do you get to the nailing flang to fasten to and how do you relock it?
  3. Guest_ | Oct 15, 1999 06:56pm | #3
    With a siding (zip) removal tool. You should be able to get one at your local building supply place. It is very easy to use (it must be, cause even I used it successfully the
    i first
    time!). With this tool, you can remove and replace siding from any spot you want.
    Rich Beckman
    1. Guest_ | Oct 19, 1999 06:17am | #5
      *Rich is right. If you aren't sure how to do it & aren't willing to take the chance, ask the supplier for a sub recomendation & build it into the bid.
  4. olmsted_carpenters_co. | Oct 19, 1999 06:17am | #4
    Remove the flange?
    Cut the siding?
    Weatherproof it?
    Thank you
    Carl
