new Xshop table saw by skill
ANDYSZ2 | Posted in Tools for Home Building on June 13, 2005 03:03am
Has anybody seen this it is exclusively at Lowe’s but I haven’t seen it yet.
It is setup to use a jig saw as scroll saw/ a belt sander can be locked in /a drill press and a router table all with plates that latch down on the table and storage underneath.
ANDYSZ2
I MAY DISAGREE WITH WHAT YOUR SAYING BUT I WILL DEFEND TO THE DEATH YOUR RIGHT TO SAY IT.
Remodeler/Punchout
  1. displacedtex | Jun 13, 2005 11:16pm | #1
    I think it looks pretty cheap, and very cheesy. I don't care much for skil except for their worm drives, and Ridgid makes a nicer one... It has the same cheap feel as everything else in the same price range.
      trimcarp | Jun 14, 2005 01:20am | #2
      Yep, cheap.  I just happened to look at one yesterday (by accident), it was too late before I realized it   :)
      1. ANDYSZ2 | Jun 14, 2005 05:15am | #3
        So do you think its possible that other manufacturers could make a better version or is there too  much going on to ever work?
         The idea of a multi station tool setup really appeals to me as I would like to set up my small enclosed trailer with it and be able to operate  inside the trailer.
        Alot of the home repairs I do are  one cut or some small fabricating.
        The neighborhood that I do alot of work in have tight drives and it would be hard to put a larger trailer  in so I can't go bigger.
        Remodeler/Punchout
          trimcarp | Jun 15, 2005 12:33am | #5
          I would not buy it.  A smallish table saw with a router table and a cheap little "drill press" that you stap a drill into and I think there was something else too.  I need my tools aetup and ready to use in conjunction with each other - the idea of having to remove the drill press and/or the router and fence to use the table saw does not fit how I work.  Now if it was set up to flip out of the way then I would look at it.
  2. alwaysoverbudget | Jun 14, 2005 05:22am | #4
    i have a "friend "that has one.use it to drag around to rental property. if someone steals it i ,i mean my friend wouldn't lose any sleep. it cuts  as good as any small cheap saw. fence is  just a guide to  go by,sure isn't a bysmeyer. if you need to set up all this stuff in one unit it's hard to beat,heck a router table cost 200. use it for a while,then buy a better one and use this one for all the attachments and put a dado blade on it so you won't have to mess with that everytime you need one. larry
Outdoor Lighting
