Newbie needing help with a simple greenhouse
mpalatnik | Posted in Construction Techniques on May 30, 2023 11:02pm
Hi guys,
 I am an utter newbie. Please forgive me and go easy. This is a simple backyard greenhouse (12x10x8.5 or so). Although my area will not experience snowfall, there is a good chance of heavy wind.  After conversation it seems like the plans that I built from do not follow proper framing principles.  Given that I’ve come this far, how do I make the most of the structure I have?
Should I be blocking between the rafters at the jack leg? Collar ties? If so, where for collar ties?
PS: yes im aware of the water standing issue with the polycarbonate orientation
Thank you
Max
    ct_yankee | May 31, 2023 06:08pm | #1
    If it were me, I'd simply add plywood gussets at the end joint in the 2x's. See the .PDF I've attached.
    File format
    1. mpalatnik | Jun 01, 2023 12:05am | #3
      Thanks for the reply. Just so I can understand - why gussets over collar ties?
    2sheps | May 31, 2023 10:00pm | #2
    The gussets seem like a good idea, I'd add that they should probably be treated or at least have exterior glue.
    ct_yankee | Jun 01, 2023 08:48am | #4
    What collar ties?
    If looking at gable roof framing, the rafters comprise the diagonals of a capital 'A' and the collar tie would be the horizontal. I don't see a collar tie in your pics.
    1. mpalatnik | Jun 01, 2023 05:21pm | #5
      I'm asking if Collar ties should be added - it was suggested to me by someone but I dont know what to believe.
