Newel Post Base Bracket Needed
basswood | Posted in General Discussion on March 28, 2006 03:24am
I want to find this exact bracket. I have used them several times to reinforce existing newels that are wobbly but do not have access below. They work great, but I can’t find them anywhere.
They wrap around each of the four corners, and a set of four gets you 16 to 24 screws into the floor and 16 screws into the newel post. A sturdy retrofit/fix. Then I trim with base over the brackets to match existing base or newel.
Anyone know of a source? I have seen other “L” brackets, but none work as well IMO.
    IMERC | Mar 28, 2006 04:02am | #1
    Got a pick of the ones you use????????
    The 4JS post mounting system ones....
    WOW!!! What a Ride!
    DDay | Mar 28, 2006 04:25am | #2
    If you plan on covering it anyway, why not pocket holes?  Two on each side would be plenty strong.
      basswood | Mar 28, 2006 04:35am | #3
      The brackets increase the effective footprint of the newel and the "around the corner" hardware adds a ridgidness independent screws or simple "L" brackets can't match...I am looking for a very sturdy fix for a customer with "wild children" who will be tugging on it.
  3. silver | Mar 28, 2006 05:57am | #4
    ever tried sure tites
    9" lag bolt- 5" goes into floor framing- 4"machine threads for a hole drilled into bottom of newel-tighten with nut through access hole--use a dab of polyurethane construction adhesive on bottom of newel-strong like borsch
    if I can't go through floor-I use suretites.
    silver
  4. riverman | Mar 28, 2006 06:07am | #5
    Unless I need a boat load of them I usually weld up my own, I make them from 1/8 angle or slightly thinner. Weld two corners and leave one side open. Flanges as wide as I can make them and still be able to hide with the trim. I'm pretty much set up to do it so it takes me less time to fabricate a set than it takes to hunt down and buy one. Plus I can have it now instead of a week later.
      basswood | Mar 28, 2006 02:57pm | #6
      "I usually weld up my own"Hey!! That's not fair.I've been following your threads, thinking, "Wow, nice shop! Woodworking, metalworking...you got it goin' on." I'm just starting to set up my shop.BTW I posted a pic of my critter in your "Photo Album" thread yesterday.
      1. riverman | Mar 29, 2006 03:06am | #9
        you got it goin' on." I'm just starting to set up my shop.My guess is I have quite a head start on you, your probably just a pup and I'm gaining on father time. Basically I started welding my own out of necessity. Half the time I couldn't find anything to fit or worse I would buy something only to have to modify it anyway. Yup I noticed the pup, I'm looking through the kids photos to find something to compliment your super dog.
  5. firedog | Mar 28, 2006 06:17pm | #7
    hey have you ever tried the square plate (maybe 1/8" steel)that you screw into the bottom of the newel w/ 5 screws. it is maybe 3/8" bigger on all sides of the newel w/ 8 screws that now hold it to the floor. trim out as you said and i found them very strong. i have 2 wild boys myself!! i have also made my own from heavy gauge (1/8" plus) aluminum.
    BillHartmann | Mar 28, 2006 08:15pm | #8
    Ask This Old House used these.
    http://www.coniferproducts.com/prod01.htm
    Looks like you can only get then with the trim.
