No-coat corner bead: run it over tape at wall/ceiling intersection?
Drywall finishing question:
Think of the intersection of walls and ceilings and soffits and walls: where an outside corner butts up against a plane. If I’m using no-coat (paper-faced, tape-on) corner bead, should I tape the inside corners first and run the bead over the tape, or stop the tape short of the bead?
Running it over the tape seems like a lot of build-up.
