Considering a deck off the second level and would like to have it dry underneath over the main patio deck. Southeast Idaho area. Weather is occasional rain showers and winter snow with intermittent melting. My concern is how to get some type of drainage or if it needed, and how to seal it up. I would like to do under the deck with nice tongue and groove wood for the ceiling of the patio. Deck size is 20×25. Thanks
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
A T&G cieling means that you have to have a true roof and then deck floating over that. No water can get to the T&G.
The way I do this is to sheath with ply or advanteck, then roof with EPDM, then sleepers to float a deck. Use the search feature here to see numberous discussioins on the details of how, with photos
Thank you for the return. What is "EPDM"?
A long name like Ethlyne propyl diene monimer.If you look at and handle the material it is like the innertube for a tire. Best thing going for flat roofs IMO. Nicknamed rubber roof
Here's an option for creating drainage & dryspace.
http://www.timbertech.com/products/dryspace.aspx
You could then consider a beaded soffit in vinyl. I did my front porch ceiling with it and I think it looks awesome. Colors are a bit limited. I used Certainteed triple 2" smmoth beaded panel.
Good luck.
fiberglass the top deck....
or even better, look into grailcoating it
http://www.grailcoat.com
Treat every person you meet like you will know them the rest of your life - you just might!
I would consider using T&G flooring for the deck floor as well. It will create a watertight surface for you.
It is common here in the Cleveland, Ohio area to see porch floors of T&G acting as the weatherproof covering over a portion of a home's basement where the basement extends into the area beneath the porch assembly.
The difference between stupidity and genius is that genius has its limits. -Albert Einstein
http://www.peteforgovernor.com
