no sub-flooring
clkharr | Posted in Energy, Heating & Insulation on December 21, 2008 11:36am
We noticed that our first floor wood flooring does not have any sub-floor beneath it. I have begun insulting our 1900’s bungalow crawlspace with some perimeter insulation and 6-mil vapor barrier on the dirt floor. The last step in this process would be to install some spray foam insulation along the foundation/ joist.
Should I install some un-faced batt insulation between the floor joist or leave the floor alone and rely on the perimeter insulation and VB? If I do install un-faced batt insulation what R value would be recommended? Thanks
  1. DanH | Dec 22, 2008 12:23am | #1
    I'd recommend housewrap stapled to the joists, to prevent air infiltration. You could place unfaced FG batts above that if you wanted. Unfaced bats without any covering will be largely useless, especially with the "holey" floor.
    The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one. --Wilhelm Stekel
  2. Snort | Dec 22, 2008 01:06am | #2
    "I have begun insulting our 1900's bungalow crawlspace..."
    yo mamma was a shack, n yo daddy was a pigpen?
    If you do the rest right, you shouldn't need anything in the floor... but, where are you? and how tall is the crawl?
    http://www.tvwsolar.com
    Now you see this one-eyed midget
    Shouting the word "NOW"
    And you say, "For what reason?"
    And he says, "How?"
    And you say, "What does this mean?"
    And he screams back, "You're a cow
    Give me some milk
    Or else go home"
    1. Bpawb | Dec 22, 2008 03:43pm | #4
      "yo mamma was a shack, n yo daddy was a pigpen?"
      Cracked me up...can't stop laughing.................
    harryhandsaw | Dec 22, 2008 06:54am | #3
    I would leave the floor alone. The crawl space should be treated like a basement with the walls insulated and with vapour barrier. I have seen instances where the floor was insulated and that lead to problems with the insulation trapping moisture and causing problems with mould and rot.
Grout-Free Shower Panels
