non-dirt-attracting caulk
brucet9 | Posted in General Discussion on August 28, 2009 08:11am
A painter told me today of the problem with many caulks that seem to bleed stickiness through the paint, causing lines of dirt to appear after a few months on caulked joints of otherwise clean trim. He said that he had once used a caulk that would not do that, but he can’t find it any more.
Anyone know the problem and the best caulk to avoid it?
BruceT
    Jeff_Clarke | Aug 28, 2009 01:43pm | #1
    The kind you can paint.   Seriously.
    1. brucet9 | Aug 28, 2009 09:56pm | #2
      According to my painter friend, many caulks have components that can bleed through the paint, making the caulked areas a little sticky so that they catch airborne dust more than the rest of the surface.If it actually does happen, I haven't noticed it and apparently neither have you.BruceT
  2. Hudson Valley Carpenter | Aug 28, 2009 10:06pm | #3
    Dap: Painter's Acrylic Latex caulk, about $1.40/10oz tube at HD.   I've been using it for years without problems.
    Recently repainted the insides of some old built-in cabinets, using several tubes of that caulk to fill shrinkage voids up to 1/4".  Painted over it the next day.  Looks like it grew there.
    Comes in various colors too.
  3. Piffin | Aug 28, 2009 11:05pm | #4
    He might be apinting over it too soon or not well. I have never seen it happen
    1. JTC1 | Aug 28, 2009 11:53pm | #5
      >>He might be apinting over it too soon or not well.<<
      Seems to be SOP for some painters to caulk and immediately paint over.  I would believe it could bleed if this is how it is applied.
      Have even seen some paint crews with a caulk man running ahead of the painters -- caulk application to paint over = less than 15 minutes.
      I think it all goes back to the good / fast / cheap triangle; this practice would be produced by choosing fast + cheap.  I am sure the job looks good at least long enough to get paid.
      Jim
      Edited 8/28/2009 4:56 pm ET by JTC1
      1. Hudson Valley Carpenter | Aug 29, 2009 07:17am | #6
        FWIW, the recommended minimum drying time before painting is two hours, for the Dap painter's acrylic latex caulk, commonly used in the trade for both interior and exterior filling.
        Edited 8/29/2009 12:19 am by Hudson Valley Carpenter
        1. JTC1 | Aug 29, 2009 05:31pm | #7
          >>.....minimum drying time before painting is two hours.....<<
          I understand completely, and that it is not the proper procedure.
          I'm just saying that I have seen this caulk-to-paint elapsed time of 15 minutes more than once. "Professional" painters, not my jobs.
          If one were to apply latex caulk and paint over it before the caulk dries; I would think the caulk would tend to dissolve (at least a bit) in the paint.  The resulting caulk+paint areas would probably not dry properly, possibly remain somewhat tacky and attract / retain dirt -- the condition mentioned by the OP.
          The resulting paint job would probably look good because the dirt lines will not appear for a while -- long enough for the painter to get paid.
          Good, fast, cheap - you only get two.......
          Jim
          1. Hudson Valley Carpenter | Aug 29, 2009 06:03pm | #8
            Jim, I probably should've just written that post to the OP but you and Piffin got me thinking about precise drying time so I checked what it said on the tube, then added it as a tag to your brief discussion.
            I can't say I'm surprised to read that some crews paint over latex caulk almost immediately after applying it.  The only paint contractor I ever worked for, back in the sixties, never worried about drying time with caulk or glazing.
            Me?  I read and follow the manufacturer's recommendation on all the many kinds of caulk and paint products.
          2. JTC1 | Aug 29, 2009 08:47pm | #10
            >>Me?  I read and follow the manufacturer's recommendation on all the many kinds of caulk and paint products.<<
            That takes the sport out of it!
            Also changes the good, fast, cheap equation, as now you have selected "good" as an option ---- consequently either fast or cheap suffers somewhat.
            Keep up the good work - always my choice.
            Jim  Never underestimate the value of a sharp pencil or good light.
    2. brucet9 | Aug 29, 2009 07:38pm | #9
      Thanks for the feedback, everyone. I was skeptical of the guy's statement, but, as my wife so willingly tells me, I don't know everything, so I asked.Since most caulking that is visible is at top edges of trim, I'm guessing that he's seeing accumulated dust in those areas and associating it with the caulk.BruceT
  4. kboff | Feb 08, 2022 02:35pm | #11
    I have experienced this problem many times, even when the caulk was dried thoroughly before painting. With a year or two the caulk bleeds black through the paint. My remedy is to prime the black caulk marks with an exterior stain-killing primer and repaint with the finish paint.
A New Approach to Foundations
