per the N.C. version of this code, the permitter of slab foundations shall be provided with 1″ of foam insulation (R-5) see appendix Q, and per paragraph R324.3.5.2 this foam is to be protected with a cementitious coating. Does anyone out there know of a simple way to apply a good coating to Dow blueboard? On a past job we had to attach wire and then stucco over the foam. This method was very time consuming and thus expensive. I would like to know how others have met this requirement. Thanks.
![](https://images.finehomebuilding.com/app/uploads/2024/05/23122928/01232448-bracing-for-storm-thumb-16x9.jpg)
Insurance industry research shows that stout roofs, strong windows, and metal connectors can help protect houses from high wind, hail, and hurricanes.
The guys here do it with Sto, Parex, or some other competitor brand of EIFS stucco.
Here's my DIH.
18"deep footings? or less? Protect the foam with 2 @ 3/4" layers of ply wrapped in plastic film for slickness. Rope handle on the outer layer. Back fill with dirt that will not collapse. Pull out outer ply, then inner ply, then plastic. Pour pea gravel slurry in resulting trench.
1 cu-ft slurry will fill 5.3 feet of 18" x1 1/2" trench.
SamT
ps. DIH is drug induced hallucination. also known as caffien withdrawals.
I am not so much interested in protecting the underground foam, it's the stuff above ground that is giving me fits. Like your DIH idea. Why are you giving up caffeine? Have they now banned this in places where you live?
I'M Not Giving It UP!!!
Just bad times before the first cuppa.
SamT
Edited 6/18/2004 7:12 pm ET by SamT
Dude, drop a few actifed in yer beer..you'll ferget all about caffiene..
doin Comtrex and Bud today..almost have my voice back..this ain't a summer cold, it's bioterrorism..
Yer right about that.
Scariest trip I was ever on, scarier than a belladonna induced halucination of a 3 foot tall spider with glowing 3" RED eyes, lemmee tellya, is an actifed alergic reaction.
I thaynk I'll jest trow in some more grounds, think yu.
Samt
Cement board? Nail at the top, color coat, and cover the nails with siding?
I can't see the details from here.
SamT
