Northeast Russian Fireplace mason needed
Icnlfn | Posted in Help/Work Wanted on February 16, 2016 08:42am
I live north of New York City about 50 miles. I’m building a new, energy efficient home, with superinsulated walls and a grass roof. It’s going to be a model of efficiency, yet very stylish. At the heart of the home, in the basement, I have plans to put in a massive fireplace. However, I am having trouble finding a qualified mason to design and build a Russian fireplace. None of the local masons have experience with this style.
I need an experienced mason who has designed and built large, efficient, masonary fireplaces. My contractor just started the driveway yesterday, 2-16, so I will need someone within the next month or so. If you live in the NJ, NY, CT, VT, PA or ME area, please write.
You can email me at [email protected].
Thanks,
John
  1. junkhound | Feb 16, 2016 10:56am | #1
    Best post what your expected payout for this work is.
    I know masons in Seattle, but probably past your price range, even without travel costs?
  2. catmandeux | Feb 16, 2016 06:05pm | #2
    Try this:  Masonry Heater Association directory
    http://www.mha-net.org/member-directory/
  3. mark122 | Feb 16, 2016 06:39pm | #3
    do you have a detailed design? not having one would be the only reason i can see being the reason for not finding someone that can do it
  4. calvin | Feb 17, 2016 07:58am | #4
    John
    The tip to look at the MHA site is a good one.  This organization is more like the euro guilds.  I know you can find a member to vett in your area.
    and do this b/4 you break ground as the key to these heaters are the heat holding mass and that requires substantial footings.
    we've used our soapstone heater now for over 25 years and I can attest to its ability as both a primary and secondary heat source.
    best of luck.
