Not sure how to fix this
cutawooda | Posted in Construction Techniques on October 17, 2012 08:48am
when looking at the photos, the obvious answer is to add concrete,however,  I think the new concrete will bust when the carpet crew put in their tack strips. Need to hear how to fix it right. It is happening at both exterior doors.
  1. calvin | Oct 17, 2012 09:01am | #1
    cuta
    Is that a wood plate under the door?
    MarkH | Oct 17, 2012 09:34am | #2
    Cut or chisel out a channel in the concrete and insert a PT wood filler strip to nail the tackless into.
    xxPaulCPxx | Oct 17, 2012 12:19pm | #3
    You could drill and secure your own tack strips with concrete screws, and fill the spalling with PL Premium to help keep the bond.
  4. DanH | Oct 17, 2012 08:04pm | #4
    Fix it with an epoxy patch compound.  And try to convince the carpet crew to glue down their tack strip.
    You don't want a piece of wood there as it would be a magnet for rot.
    The other option is to not use carpet up against the door, but have a vinyl or tile skirt.  In our part of the country you never see carpet up against an exterior door.
  5. Piffin | Oct 17, 2012 08:29pm | #5
    I am not sure, but I think I see signs of water penetration under those doors. If So, You don't want carpet there until you pull the doors and re-set them, correcting the problem so that water does not ruin the carpet
