notching floor joists
ldcinc | Posted in General Discussion on September 22, 2006 10:03am
Need help!
Im remodling a house in Haverford Pa. and the pluber needs to cut the floor joists to run his pipes.  What are the rules/codes on how much of the joist can he cut out or drill a hole, with out weaking the joist?
I know your going to need the size of the joist, but i havnt opened the floor just yet.  Can any one give me the formula for joist notching.
thanks  ldcinc
    Sphere | Sep 22, 2006 10:28pm | #1
    The "formula" is don't notch. Drill IF you have to. I believe no more than 1/3 joist width and above center.
    But I only do plumbing being held at gunpoint.
    " If ya plan to face tomorrow, do it soon"
  2. sungod | Sep 22, 2006 10:45pm | #2
    If your "Plumber" does not know how to run it to code, he is not a "Real" Plumber.
    1. ldcinc | Sep 22, 2006 11:04pm | #3
      I allways like to double check, since so many trades  now adays like to take short cuts..
      Get in -- get out,,,, attidues
      1. Framer | Sep 22, 2006 11:07pm | #4
        How many joists does he have to drill through?Sometimes you have to put a plumbing box in.Joe Carola
      BillHartmann | Sep 23, 2006 03:57am | #10
      I thought that code for a real plumber, was not to notch it.Just cut it out of the way with sawzall or if a master plumber a chainsaw.
      1. MSA1 | Sep 23, 2006 04:42am | #11
        You beat me to it. I once bought a house where a plumber cut through 3 of the 6 floor joists in a first floor bathroom. Luckily the joists were 2x6 spanning about 12' so no one noticed the extra spongey floor.
      2. user-14025 | Sep 23, 2006 05:13am | #12
        I like that one,  only thing worse than plumbers are HVAC hackers.
        Bobby
  3. Piffin | Sep 23, 2006 12:11am | #5
    try this
    1. ldcinc | Sep 23, 2006 12:24am | #6
      Thanks so much!   Thats exactly what I was looking for.
      By the way, were did you get that? can I get more info. is that from a web site?
      ldcinc
      1. Piffin | Sep 23, 2006 12:34am | #7
        I dunno, I downloaded it from a thread like this here four years ago or so.
      2. jacktchick | Sep 23, 2006 02:49am | #8
        there's a website on that pdf. it's http://www.wwpa.org
        -nickt.-
        BillHartmann | Sep 23, 2006 03:56am | #9
        http://www.codecheck.com/pg00cover.htmhttp://www.codecheck.com/pg03_04building.html#fb8notching
  4. ad73 | Sep 23, 2006 02:42pm | #13
    An old house in Haverford the floor joists are probably already notched.If your not changing the layout youight be able to use old notches and nail plate them.
