novice needs advice
art | Posted in Construction Techniques on June 20, 2002 03:17am
I’m a moderately accomplished woodworker but I’ve never done much house construction. I’m faced with the task of installing a new window in my existing house. I plan to use an Anderson double hung. The construction is 2X6 studs with T-111 on the outside and sheetrock and paneling on the inside. Any advice on how to proceed would be appreciated.
Thanks, Art
  1. joeh | Jun 20, 2002 05:49am | #1
    Art, The Taunton Store is the book store. I think there is a book that covers windows & doors that is articles excerpted from FHB over the years. You'd probably find what you are looking for in there. Joe H
    1. art | Jun 20, 2002 06:17am | #2
      Thanks, I'll check it out. Art
  2. Dunnwright | Jun 20, 2002 09:30pm | #3
    ART, there are all kinds of things involved. Is it a bearing wall? because the first thing you need to do is put a header in. so this means that the hole you cut is going to be larger than the hole you need for the window. to cover this up, the easiest way is wide trim. but that probably won't match existing trim. this is only the beginning of what to expect.
  3. vasalesman | Jun 21, 2002 01:12am | #4
    PLAN!  Go to http://www.andersenwindows.com and download their installation instructions as well as their pro details drawings.  Make your mistakes on paper and draw out exactly what you'll have at the head, sill, & side jambs.  Make it detailed.  Determine what's inside the wall before the sawzall finds the phone line, or worse.  Once you start the job, know what comes three steps after where you're at.  If you will have someone helping you, don't let them rush you.  Especially in new territory, work carefully and slowly.  If a problem arises, STOP and figure it out before going any further.  Be positive the window is square and dead level in the opening...have you checked your level?  Don't make the rookie mistakes of using spray foam insulation or shimming too tightly.  If the outside of your house is painted, be sure your caulk will be paintable also.  Good luck!
    Al
  4. JCJF | Jun 21, 2002 05:59am | #5
    Art , I would use a double sill plate.and also add in a  2x6 under my header if I had the room and install the window to the framing, then side with t111. and silicone then trim the exterior with 3/4 pine or cedar use stainless nails  for the trim. the trim will be slightly wider than the window, by that I mean it will extend an 1/8 to a 1/4 past the vinyl , and you might have to rip your extension jams down a bit but this way the window won't leak.
