nut sizes on threaded rods: log home
PurpleThumb | Posted in Construction Techniques on September 13, 2005 03:33am
I’m catching up on some things a careless builder (don’t ask!) left undone on a log home.  Saddle notch corners are reinforced with long thru-bolts.  Some of these are missing the nuts to tighten them up as logs shrink.  I took one of the original nuts to the hardware store, where it fit perfectly on a 5/8″ coarse thread bolt.  Bought some 5/8″ nuts that fit the same bolt, but they do not want to thread onto the thru-bolts that the original nut threads onto perfectly.  What am I missing here?
    BossHog | Sep 13, 2005 03:36am | #1
    Could you have gotten some fine thread nuts mixed in with the coarse thread ones?
    Dear Abby, I am a twenty-three-year-old liberated woman who has been on the pill for two years. It's getting expensive and I think my boyfriend should share half the cost, but I don't know him well enough to discuss money with him.
  2. calvin | Sep 13, 2005 03:37am | #2
    mm's
    Quittin' Time
  3. Piffin | Sep 13, 2005 04:42am | #3
    He bruised the threads in the building process and the nuts wouldn't thread on. You need a die to clean the threads
  4. Notchman | Sep 13, 2005 05:35am | #4
    Is the bolt galvanized and the nut not?  or vise-versa?
    1. junkhound | Sep 13, 2005 05:53am | #5
      Also, there are 3 thread classes, 1,2, and 3, with 3 being the tightest tolerance. A low end sized class 1 bolt will let any nut thread onto it, a high sized class 1 only a class 1 nut, etc.
