I am installing 2 1/4″ by 3/4″ T&G
oak flooring over a 3/4″ t&g plywood
subfloor with old self adhesive vinyl squares on it. There is a well ventilated crawl space under the floor. I’m wondering if a vapor barrier is needed between a plywood subfloor and hardwood flooring?
Thanks for any response.
Do more research! Any vapor barrier will become ineffective once you put nail holes in it. The crawl space, even well ventilated, will change the moisture content of the wood above. I guess this will depend on the climatic condition of your area, but that crawl space looks like a trouble. Did you consider a floating floor? Good luck. p.s. I would remove the old vinyl flooring. Wouldn't it be too soft as an underlayment for wood flooring?
I am installing 2 1/4" by 3/4" T&G
oak flooring over a 3/4" t&g plywood
subfloor with old self adhesive vinyl squares on it. There is a well ventilated crawl space under the floor. I'm wondering if a vapor barrier is needed between a plywood subfloor and hardwood flooring?
Pete, lift your tiles, and lay 30# asphaltic felt
as an underlayment. If the tiles leave the plywood too lumpy, you'll have to clad the floor with a minimum of 1/4" lauan or better.
