I am replacing oak stair treads in my home and want to know if there is a better way to fasten them other than nailing them through the top of the tread?
![](https://images.finehomebuilding.com/app/uploads/2024/04/10100343/01232346-chimney-cricket-hdr-1-thumb-16x9.jpg)
Easy-to-make tools simplify the framing, while time-tested flashing techniques make it last a lifetime.
there are a couple of different ways to fasten them. one would be to drill and counterbore for screws then plug the holes with wood plugs that match the treads. sand the plugs flush and it will look very nice. the other way is to use trim head screws. these have a small head the size of a finish nail. then putty the hole. use some panel adhesive under to help prevent the treads or risers from developing a squeak.
johnv,
Joseph Fusco
"The price of apathy towards public affairs is to be ruled by evil men." -- Plato
*When building with exposed treads, I always use construction adhesive and predrilled screws. Joe's suggestion of placing one under the baluster is a great one,unfortunately the rest will have to be plugged. With a little time spent on the sander, you really won't even notice the plugs. Good Luck.
*johnv,Unless you cut a sliding dovetail into the stringer and tread, I'm afraid you will have to glue and nail or screw down each tread. If you use only construction adhesive under each tread you might get by........but I wouldn't guarentee the results. The nail and/or finish head screw holes are small and if filled properly usually just disapear in the grand scheme of things.Good luck,Ed. Williams
