How do you go about laying oak strip flooring over a concrete slab? Can I put a plywood subfloor over the slab and then go over that with the strip flooring? Many thanks.
T2
Listeners write in about shower panels and cordless tools and ask questions about old wiring, air leaks, and gutter covers.
That works, since you can nail to the ply. Or you can glue the oak directly to the slab, if it is engineered wood (aka plywood).
Do it right, or do it twice.
Is 3/4" ply enough of a subfloor or will it require more?
ELCID
Do you need to put a vapor barrier between the slab and the ply? and also between the ply and the oak?
I don't know , do I?
Here is a link to NOFMA (NOFMA: The Wood Flooring Manufacturers Association)
http://www.nofma.org/installation2.htm
Coldbond mastic skim coated over concrete. Broom 6 mil plastic over skim coat. Apply 1/4 x 1/4 x 1/4 coldbond mastic to plastic. Lay minimum 5/8 CDX into glue. Nail with 1 1/4" concrete nails 10" on center, 1 1/2" nails for 3/4 cdx. Plywood needs to be below 10% moisture content. Stay away from HD. Go to a lumber yard that houses their ply inside. The lower the moisture level the better. Sand plywood joints level, lay out 15 lb. felt and then nail the floor. GW
Thanks Greg
