My house was built in ’47. It has very squeaky oak floors throughout, except wet areas. The sub floor is 1×8 lapped fir, then the weird part is that I have furring strips (1×2 sleepers) on 16″ centers running directly above/parallel to the joists. the finish oak floor is nailed to the sleepers. (each layer is set perpendicular to the previous)
Does anyone have any idea why a floor would be constructed in this way? there may as well not be any sub floor – as the load essentially bypasses it and goes from sleeper to joist – no support in-between.
Finally, to reduce movement of finish floor as you step between sleeper supports (especially on end joints of finish floor that fall between) would anyone recommend injecting a low density foam or something to transfer load to the sub floor?
Any advice welcome!
Thank you,
Mike reamer, Olympic, WA.
My house was built in '47. It has very squeaky oak floors throughout, except wet areas. The sub floor is 1x8 lapped fir, then the weird part is that I have furring strips (1x2 sleepers) on 16" centers running directly above/parallel to the joists. the finish oak floor is nailed to the sleepers. (each layer is set perpendicular to the previous)
Does anyone have any idea why a floor would be constructed in this way? there may as well not be any sub floor - as the load essentially bypasses it and goes from sleeper to joist - no support in-between.
Any advice welcome!
Thank you,
