Oil finish for fir t&g porch floor
berekki | Posted in General Discussion on June 15, 2011 10:05am
I am installing beautiful clear, vertical grain flooring on the covered  front porch of my 125 year old house.  I don’t want to paint it, I do want to seal all surfaces before it is installed, and I want a finish that will complement the aged look of the house.  The house has been restored, leaving many of the old finishes intact.  I have pretty much dismissed the idea of boiled linseed oil but am definitely wanting the soaked in oil finish, not a glossy surface coat.  I don’t mind recoating every year.   I’ve used modern deck sealers on other projects and find that they do not soak in enough and need recoating twice a year.  Are there any marine products that would work?  Any suggestions?
  1. Scott | Jun 16, 2011 10:01pm | #1
    In my experience marine finishes are pretty much film-forming rather than penetrating.
    Here's a finish I've had lots of luck with:
    1/3 BLO
    1/3 pure tung oil (and I mean pure, not any sort of tung oil finish) Here's a link:
    http://www.leevalley.com/US/wood/page.aspx?p=20049&cat=1,190,42942
    1/3 oil based poly (gloss, semi, or satin)
    Brush a light coat on, wait 20 min, wipe all excess off. Wait 12 hrs. Repeat as many times as you like. It will build to a very nice finish.
    But remember....cedar flooring!?!?!?!?!? Pretty soft stuff, even though VG. You can expect lots of "character" over the years.
    1. davidmeiland | Jun 17, 2011 12:04am | #2
      Cool recipe
      I should try that some time.
      The OP said he is doing VG fir. A cedar floor would get shredded pretty quick.
      1. Scott | Jun 17, 2011 12:20am | #3
        Sorry, my alzheimers must be flaring up... don't know why I thought cedar.
        But as for the finish mixture...it's a winner. Super multi-use finish. It pops the grain out nicely, then you can finish with whatever gloss/semi/satin you like. I wouldn't put a water based product over it though, unless it sat for a few months.
          Julimor | Jun 17, 2011 09:43am | #4
          How would this work on clear heart redwood if it wasn't followed up with a sealing finish?
          I'm replacing the redwood skirt and steps on my hot tub.  I'm looking for a finish that will provide UV and mildew protection while allowing the natural beauty of the redwood to show through.  So I'll be going with a clear finish.  But I don't want to seal the wood with varnish.  I will just reapply the oil as needed.
          BTW, the hot tub gets full exposure to the weather.  It's not under any cover, except the sky. ;)
          1. Scott | Jun 17, 2011 12:56pm | #5
            The sealing finish would be critial. Tung oil is very susceptible to mold/mildew, at least in my climate. I made the mistake of leaving some cedar chairs outside, but under a roof, and they got all nasty.
            You could use something like Minwax's Helmsman Spar Urethane or McCloskey's "Man'O War" Spar Varnish.
    2. baytonemus | Aug 20, 2014 12:03am | #6
      Stain?
      I'm intrigued by this concoction. I'm also refinishing what I think is a fir porch floor - 90 years old - but I'd like to darken it a bit. Any issues with first applying a stain? I don't usually associate tung oil with stain, but I'm no expert.
      Thanks.
Two Ways to Test Windows
  • The New Old Colonial
