I have this really old bathroom with the original 1929 plumbing fixtures. Above the tub, there are 2 sets of hot and cold faucet handles. I want to replace them as well as the pipe leading up to the shower, which means opening up the wall. There’s no sheetrock here; it’s old plaster. Once I replace the pipes and hardware, to what do I attach the new sheetrock to cover the hole? There won’t be any studs. Any suggestions? Thanks!
Bad Ass Extension Cords makes quality cords in different lengths and thicknesses, with bright color options as well as customizable branding to keep cords from being lost on the job.
Why no studs? Anti-gravity? Monocoque construction? Splain, please.
*We have to assume that the construction is lathe and paster or possibly gypsum board and then plaster and that you have just cut a slot/holes to get to your pipes. If this is the case, then I would suggest a piece of 5/8 plywood placed against the back of the wall and then screwed through from the front. I might try to countersink the screws to keep them flush to the finished plaster. Then fill in the gap with 2 bits of 3/8 gyprock or whatever it takes to make it even. Then plaster. enjoy. Derek
*Derek's solution has worked for me also. However, several times it was just easier to remove plaster/lath back to the closest studs. Be thankful you don't have old tile up there also.have funscc
I have this really old bathroom with the original 1929 plumbing fixtures. Above the tub, there are 2 sets of hot and cold faucet handles. I want to replace them as well as the pipe leading up to the shower, which means opening up the wall. There's no sheetrock here; it's old plaster. Once I replace the pipes and hardware, to what do I attach the new sheetrock to cover the hole? There won't be any studs. Any suggestions? Thanks!
