old house insulation
doughomiak | Posted in Energy, Heating & Insulation on October 17, 2012 10:58am
I have an old house build around 1850.Their is little to no insulation inside the plaster and lath outer walls. I wanted to know if I could frame all new outer walls infront of the exsisting walls, with out doing anything to the exsting wall. In the new wall I will be insulating and running all new electrictal. Is this common to do, will it cause a moisture problem?
                                              Thanks in advance
                                                  -doug
  1. calvin | Oct 18, 2012 09:23pm | #1
    I can't say that I've seen it done.........
    How do you plan on building this wall outside your existing structure?
      xxPaulCPxx | Oct 23, 2012 08:43pm | #3
      By my read he ment inside his exterior walls
      1. calvin | Oct 24, 2012 06:02am | #4
        Thanks paul
        My reading comprehension was way off.
          xxPaulCPxx | Oct 25, 2012 07:29pm | #5
          I went back to read it again and you might have been originally correct - too little info to go on.
          1. DanH | Oct 25, 2012 07:41pm | #6
            Of course, Doug is yet another one-post wonder.
  2. DanH | Oct 18, 2012 09:38pm | #2
    It's done, and in terms of moisture problems may be one of the best approaches.  You do need to be concerned that heavily-painted plaster is a vapor barrier, so the existing wall may need to be perforated somehow.  And of course the windows can be a problem.  (Note that I'm assuming you mean you'd build the new wall against the inner surface of the existing wall.)
    Knowing where this house is located would be helpful.
