On demand hot water “wannabee”.
jimz | Posted in Energy, Heating & Insulation on February 22, 2007 12:44pm
We have a power vented high efficiency natural gas hot water tank.  During a regular work week (M-F), hot water usage is from 6am-8am & 5pm-10pm.  On weekends, we may use it each day within a continuous 12 hour window.  Since the tank won’t heat unless the blower has power, the blower fan is plugged into a digital timer which has the tank heating up for our demand periods.  Am I causing a problem(s) in doing this?
JimZ
  1. rnsykes | Feb 22, 2007 02:22am | #1
    I'm no expert, but it sounds like a good idea to me, and I would assume the electricity used to run the fan is offset by the savings in wasted water that is under heated.
  2. IdahoDon | Feb 22, 2007 07:07am | #2
    The fan should shut off automatically when not needed.
  3. Jubjub | Feb 22, 2007 04:31pm | #3
    I seriously considered doing exactly what you suggest, but after talking to a plumber and doing some internet research I decided against it.  According to Canada's Safety Council http://www.safety-council.org/info/home/hotwater.html the water in the tank should be stored at a high temperature to avoid bacteria growth, specifically Legionella, which is the cause of Legionnaires’ disease.  Your method may save a few bucks, but could cause some health concerns in the long run.
    Jubjub
