i just closed on a propperty and the guy 6 acres down says he has been using gas from his land to heat his house for 36 years. Does anyone have any experience with this?
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
New wells usually require you own a certain number of acreage depending on locality. If you have the gas available on your property drillers usually will cover the cost of the well, pay you a percentage and let you tap the well for your home heat.
Half of good living is staying out of bad situations.
You mean he is on an old landfill that generates methane? Or that he has an oil-field type well that taps a pocket of decaying dinosaurs?
Either is possible but extremely unlikely to be done on the scale of a single house. Because landfill gas has to be scrubbed of its carbon dioxide and have the water vapor and nitrogen removed before you can use it in a normal gas appliance or engine. And gas from a petroleum field has higher boiling point compounds (hexane, benzene, etc) in it as well as water vapor, carbon dioxide, etc.
I could design a system to clean up such a source of gas to a usable point. But it would be much cheaper to install and fill a 10,000 gallon propane tank to last 36 years.
A few locales havce pretty clean natural gas coming up. If that is the case, you need a qualified gas well driller, at a minimum. Someone who works locally could tell you the likihood hitting gas and at what depth. And how much they charge per foot.
Could you buy into his well? Just buy a gas meter and lay a bunch of polyethylene line.
And no, a septic system does not generate enough methane to heat a house. Not even hot water. More in the order a the pilot light only. And a small one at that.
David Thomas Overlooking Cook Inlet in Kenai, Alaska
Edited 8/24/2002 1:29:25 AM ET by David Thomas
There are areas of the country (e.g., parts of W. VA) with small nat gas wells dotted around where people who own the land get "free" gas. I would be concerned with guality and contaminates, myself
It is very common out west here. I have seen people put in huge units in uninsulated machine sheds and letting them buck because "the gas is free"
Bob and WHW: Well, maybe I ought to sink my own well. Since I live in area overlaying gas fields. Except I don't own mineral rights to my 13 acres (almost no one does up here). And the hydrogen sulfide (way poisonous) is at a high enough concentration that they make sulphuric acid out of it for use in fertilizers.
I heard Taco Bell was gonna put gas collectors at their restaurants.no turn left unstoned
