ONE BAG CEMENT = ?
czella | Posted in General Discussion on October 18, 2009 12:57pm
Bon Tarde,
If I buy 1 bag of cement; 90 lbs I think it is; how many cubic feet of concrete can I expect to get using a mixture of…..
1 cement  2 sand  4 gravel and appropriate amount of water?
I am shooting for 3000 lb concrete for a footing below a porch.
I’ll use the whole bag of cement.
Thanks.
    Dam_inspector | Oct 18, 2009 01:04am | #1
    A 94lb bag of cement is exactly 1 cu ft. So you're talking 7 cu ft.
      IMERC | Oct 18, 2009 01:09am | #2
      so buy 80# sacks of high strenth concrete..
      80# of concrete (dry mix) is point 6 cubic feet...
      WOW!!! What a Ride!
      1. brownbagg | Oct 18, 2009 01:12am | #3
        a cubic yard of 3000 is a four sack
          Dam_inspector | Oct 18, 2009 01:14am | #4
          I thought it was 6 sack.
          IMERC | Oct 18, 2009 01:17am | #5
          four bags of portland...
          WOW!!! What a Ride!
        3. Piffin | Oct 18, 2009 01:34am | #7
          Well, his OP mix is close on then.
    2. Piffin | Oct 18, 2009 01:33am | #6
      actually, I think it would be six cf because the portland fills the spaces between the particles of aggregate to form the bonds, soit does not count in the volumn. I am also thinking that this mix would be weaker than 3000#, not sure.
        Dam_inspector | Oct 18, 2009 01:39am | #8
        Yes, you're right. His mix is not 6 sack, and the total is going to be shy of 7 cu ft. due to the sand filling in around the gravel. I'd lose one gravel from the mix myself.
        1. brownbagg | Oct 18, 2009 02:52am | #9
          six sack is a 5000 psi
            Dam_inspector | Oct 18, 2009 03:23am | #10
            Well, you're the expert. I don't do much of it, so I use sakrete. Or use 1 cement, 2 sand, 3 gravel.
          2. czella | Oct 18, 2009 04:05am | #11
            Sakrete concrete mix is available here; comes from Venezuela; but it is very expensive.
            We can also get Sakrete sand mix (mortar) for $14 a 80 lb bag.
            I'd like to get a load of sand and a load of gravel and mix my own.
  2. 6bag | Oct 18, 2009 04:07am | #12
    concrete is batched by weight to obtain volume.  batch plants know the approximate weigh of sand and stone (+/- for moister containt).  they know the exact weight of the water, cement and add mixtures.  one bag of cement = 1 cu ft = 94 lb.  6 bag mix = 4,000 psi +/-, 5 bag mix = 3,000 psi +/-.  the cement acts like the glue to hold every thing together.  while adding more cement will generally give concrete with a higher compressive strength, a lot more goes into it.  strengths of concrete are base on water to cement ratio, or w/c.  .54 w/c will give you 4,000 psi (i think it's .54, it's been a while since i looked at my apprentice books).  from there it is some basic math.  entrained air contain is also important.  you will loose 5% of the strength for every 1% of entrained air above 6%.  it starts to get kind of complicated, but remember this,  readi mix concrete is over engineered by about 10%.  if you order a 4,000 psi mix and you don't abuse the water, you should end up with 4,400 psi.
    for hand mixing a 3,000 psi mix, i believe the ratio is 1:2.5:5.  use as little water as possible to obtain a workable mix.  if you add to much water this ratio doesn't mean anything.  if in doubt, add a little extra cement.
    1. czella | Oct 20, 2009 03:37am | #13
      Thanks to all.
