One brick step
MelissaC | Posted in Construction Techniques on December 19, 2006 08:44am
I think I’m into something dumb or impossible, and would appreciate some guidance out of this fix….
I’ve put in a mortarless brick walkway from my front porch to the sidewalk.  That part is fine…but there is a single, short (about 4″) step just outside the gate.  I sunk some bricks on end to form the riser, and ran bricks across the top to serve as the step.
The problem is that the top bricks keep shifting, emptying the sand between them, getting even looser, and finally sliding off the riser bricks.  No one’s been hurt so far, but I think I’m pushing my luck.
Is there any way, short of building a concrete step, to hold those blasted bricks in place?
  1. pagoda | Dec 19, 2006 09:44am | #1
    PL premium & mortar works whenever i have to do one
    1. MelissaC | Dec 19, 2006 08:17pm | #4
      I googled PL premium--this sounds great.  Could I conceivably glue all the bricks together into one long step that's too heavy to shift?
      I was also wondering if there was any kind of not-very noticable stake or anchor I could place on the sides to hold things steady...all I'm finding are things that hold the edges secure.
      Thanks for your help--
      1. pagoda | Dec 19, 2006 08:30pm | #5
        we use a plastic edging that comes in about a 8' length and is held in place with long spikes , about 10"
        the first time i came upon glued interlocks they were used to build a step about 2' high and man did they hold together
        have on a number of occasions built steps on interlocks using bricks @ pl spacing joints the same as on a wall ,then filling joints with mortar  looks neat  and customers love it
      2. MikeSmith | Dec 19, 2006 08:40pm | #7
        i like to use a  soldier  course to edge the walksMike Smith Rhode Island : Design / Build / Repair / Restore
  2. notagain | Dec 19, 2006 02:49pm | #2
    Replace the last 12" or so with a one piece granite (or local sone) step.
    It'll look good and won't move.
    Rod
  3. MelissaC | Dec 19, 2006 07:32pm | #3
    Thanks for the ideas--I do like the look of granite...but what's PL premium?  I'd like to understand all my options.
  4. MikeSmith | Dec 19, 2006 08:39pm | #6
    you either have to set the bricks in mortar , or make your tread out of something else.. like bluestone
     mason supply houses sell stone treads
  5. DanH | Dec 19, 2006 11:18pm | #8
    Yeah, PL Premium or Gorilla Glue.
    People never lie so much as before an election, during a war, or after a hunt. --Otto von Bismarck
    1. DanH | Dec 19, 2006 11:25pm | #9
      Another approach is to drill them and run rods through.I don't know where you are, but in freezing climates you don't want to use conventional mortar construction -- freezing water will split things apart/
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
