Open Cell Foam Insulation: Can it ever function as a vapor barrier?
ADUinProgress | Posted in General Discussion on October 22, 2022 01:00pm
Maybe I’m misunderstanding or missing information but I was under the impression that only closed cell foam insulation forms a vapor barrier. I am being told by someone quoting on a job that 4″ of open cell will form a vapor barrier. What am I missing?
Thanks in advance.
  1. eddo234 | Oct 23, 2022 10:07am | #1
    Everything I’ve ever read says open cell foam allows moisture to pass through, no magic thickness number suddenly stopping it. Every site I just looked at says the same thing.
    unclemike42 | Oct 23, 2022 11:29am | #2
    It sounds like the only thing you are missing is a reason to trust other things this particular person told you. (like timing, price and materials they would use on the job)
    mikeljon | Oct 24, 2022 07:21am | #3
    Before insulating my shed roof with cut/cobble polyiso (from above while redoing the roofing), I checked out prices for closed cell (wowsers!). Armed with every bit of GreenbuildingAdvisor's advice I could hold in my head, I contacted the recommended "best in the area." The one my contractor friends said was the best gave me the closed cell price, and then said, "well, of course you can do 8" of open cell." I asked "but I can't use open cell in an unvented assembly!" "Well, why not? We do it all the time."
  4. eddo234 | Oct 24, 2022 10:49am | #4
    https://www.energyvanguard.com/blog/will-open-cell-spray-foam-insulation-really-rot-your-roof/
