A circuit in my house has a 20amp, 12 gauge circuit on which there are multiple outlets/lights. After fixing a GFCI circuit, that tested “open ground”, I decided to test some other outlets, on another circuit, and the first one tested “open neutral”, and then “open ground”. I shut off the power, and removed the outlet, which looked OK. After putting it back in, it still tested “open ground”. I checked another outlet on the circuit, and it tested the same. If on outlet on a circuit tests “open ground”, will ALL test that way?
The FHB Podcast team weighs in on Building Science career questions.
You really should have an electrician check things out.
Anything downstream is going to test open after a bad connection.
Open means that the wire in question is not providing continuity as it should.
Any outlet on a branch circuit after the break in the wire (or loose connection) will provide evidence of the issue.
They key to your question is that many outlets are wired sequentially in a daisy chain where an outlet is fed/wired from the prior outlet. Thus if you get a non-connection it will affect all outlets downstream but not upstream of the break. If you get an open outlet the problem may actually be at the upstream outlet.
