Opening a brick wall
| Posted in Construction Techniques on April 23, 2002 08:18am
My son-in-law and I would like to remove a 3′ wide window in his brick house, enlarge the opening and install  6′ French Doors with 1.5′ wide sidelights on each side of the door.  The doors will allow access to a newly constructed deck.  A steel lintel exists above the original 3′ wide window.  The interior ceiling joists run parallel to the exterior wall so we are wondering about the need to build a temporary stud wall to support the ceiling.  In addition, we are concerned about the best way to support the brick wall on the exterior while we open the wall and install a new header, studs, doors and sidelights.  Should we order a new lintel that extends the entire length of the opening or three separate lentils over each opening i.e. the French doors and the two sidelights?
  1. r_ignacki | Apr 25, 2002 04:39am | #1
    we have a collection of steel angles in the yard about 4' long that we use as "needles", for shoring up masonry. They get inserted perpendicular to the wall, though a chiseled out bed joint and head joint, supported by a 4x4 each end. Spacing? Try 3' apart, closer if you want less bricks to fall out.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
