Opening a “S” hook
keith_n | Posted in General Discussion on November 26, 2008 07:32am
The hanging sign at my office blew down during Hurricane Gustav. After it was repaired, I was going to hang it today. There are several “S” hooks on the chain. What is the easiest method to pry them open enough to get them off the chain? I tried pliers, pry bars, etc. There has to be an easy way I am overlooking. Thanks.
  1. calvin | Nov 26, 2008 07:37am | #1
    One end in a vise and a good size pair of channel locks.
    If not able to lock in a vise, 2-good size channel locks.
    To close up-channel locks again.
    Don't pinch yourself.
    Large screw driver rocked in one end while the other is locked down will work.  You pry open the hook
    Or buy a couple new lock rings (maybe what their called) Sort of a workingman's carabiner.
    http://www.quittintime.com/
    Edited 11/25/2008 11:40 pm ET by calvin
    Luka | Nov 26, 2008 07:42am | #2
    Vise grips and a screwdriver.
    Click here for
    ToolFreakBlue | Nov 26, 2008 09:45am | #3
    I like to use an adjustable wrench and vice grips. I also twist the loop open rather than spread the loop open. Kind of hard to explain.
    TFB (Bill)
  4. gfretwell | Nov 26, 2008 09:55am | #4
    If you are not going to reuse then, just cut it off. Side grinder, hacksaw or bolt cutter.
  5. DanH | Nov 26, 2008 02:21pm | #5
    I place the hook flat over a slot (like a vise opened a half-inch) and drive a screwdriver or chisel into the slot.
    The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one. --Wilhelm Stekel
  6. EricGunnerson | Nov 27, 2008 09:05am | #6
    Dremel with an abrasive blade will cut through them in about 30 seconds each.
  7. junkhound | Nov 27, 2008 01:14pm | #7
    2 ea. 12" or larger crescent wrenches
    bolt cutters beat a dremel or grinder every time View Image
    replace with these:
    ITEM 92412-7VGA  $1.79 pack of 3
  8. User avater
    PearceServices | Nov 27, 2008 03:15pm | #8
    two vise grips, one to hold to "S" hook, and one to open the "S" hook, TIP...  twisting the hook sideways, instead of open is much easier
    ______________________________
    Kevin
    http://www.SouthShoreRemodeling.com
Old House Air-Sealing Basics
