Optimum Circular Saw blade Height
Edkirkpatrick | Posted in General Discussion on August 2, 2019 02:26pm
I have to cut some very expensive cabinet grade plywood on my Dewalt table saw.  I have 60 and 90 tooth carbide blades that are new but I have been rethinking about what depth to use to minimize tear-out on my cuts.  I would normally set the blade to protrude about 1/4 to 1/2 inch above the material but when I couldn’t sleep last night I wondered if it would be better to set the blade at its maximum height.  I appreciate any thoughts or suggestions you guys may have.
Thanks!
Ed Kirkpatrick
Adamstown, MD
  1. ptchapman | Aug 02, 2019 07:30pm | #1
    I've always been told to raise the blade enough to where the cutting is occurring perpendicular to the front edge of the wood, in other words...high enough to be as square as possible to the face of the plywood without adding an opportunity for too much wobble. When it's lower you're ripping from the bottom up, which can cause splintering. 80-90 tooth blade for sure.
Picture-Perfect Pergola
