Options to stiffen 1/2″ subfloor for tile
![](https://secure.gravatar.com/avatar/2ff3aab975bbb593fdeda59321b5d4cd?s=52&d=https%3A%2F%2Fimages.finehomebuilding.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
The single challenge to installing tile for a 40 sq ft bath in this 1960 single-story house is the floor transition given the majority of the house flooring is in good condition. The flooring consists of 1/2″ T&G plywood subfloor and 5/16″ mahogany floor. That’s only 13/16″ – far from today’s standards but it’s adequate. However, this creates a transition challenge for a tile floor built to today’s standards.
The existing subfloor for the new bathroom’s is 1/2″. The floor is supported by 12″ joists 16″ o.c. and spans 9′ – adequate for ceramic tile.
Two possible options:
1) add 3/4″ plywood between the joists (just underneath the subfloor) supported by 2x4s running along and screwed to the joists. Then new 1/2″ subfloor and 1/4″ backer board on top. That’s ~1 1/8″ or 5/16 above existing floors.
2) use Schluter (or similar) system on new 5/8″ bath subfloor (per p4. 2019 install manual https://tinyurl.com/y2cy2n53). That’s about the same as above. Less work but I think most tile mfgs want more subfloor.
Seems like the 2nd option is easier if I’ve interpreted the instructions correctly. Any thoughts/advice?
Add 3/4" plywood or Advantech to existing 1/2" subfloor. Some tile material manufacturers won't accept reg plywood, hence Advantech.
Frankie
Thanks for mentioning Advantech.
