orbital sander pads
patsf | Posted in General Discussion on October 13, 2009 02:38am
  I have a random orbital, Porter-Cable sander Model 333.  It works well, the motor seems to last about 4 years with the amount of use I give it.  The problem is the Hook and Loop pad on the bottom of the sander.  I get a very limited number of hours of use out of the pad before it will stop holding the sanding disc.  I have not kept track of the time it take for the pad to become useless, but it seems like I’m buying a new one every few months.  Has anyone found a way to extend the life of these Hook and Loop pads?
  1. stevent1 | Oct 13, 2009 02:51am | #1
    Sounds like imbedded dust or pitch in the pad.
    I switched to Makita back in 98 and am still using the original pads on two of them. Clean pad with air when changing grits.
    Chuck S
  2. Piffin | Oct 13, 2009 03:28am | #2
    depending what I am sanding, I often hit it with the vacumn hose every time I change a disc.
    What really kills them is when a helper tries to sand something with no disc on it!
    I also notice that when I buy some of the cheaper discs, they will not hold well even on a new pad.
    I go through 3-4 pads before killing a motor or a clutch.
  3. Shep | Oct 13, 2009 03:57am | #3
    How hard do you push down on the sander when you're using it? Too much pressure could melt the hook & loop, wearing it out faster.
  4. epsaklas | Oct 13, 2009 02:39pm | #4
    Good tips, but let me add one. ALWAYS keep a sanding disc on your sander. Don't store it, or even set it down, without one.
A New Approach to Foundations
