orbital sander problem
BobC | Posted in Tools for Home Building on October 12, 2006 06:42am
i’ve got two 5″ Rigid orbital sanders. I relaly like them *except* they both are malfunctioning … in the same manner. Here’s the symptoms. When you start one, if you don’t apply pressure right away to the pad, it starts spinning…fast. If you try and sand w/it in this condition it’ll scar whatever it touches. To get around this, i’ll stop the spinning on a piece of scrap and then move the sander to the good material. The other approach is to put the sander on the good material very quickly after turning it on — before it starts spinning. works fine until you lift it up.
anyone know what’s causing this? they have a ‘lifetime’ warrenty but there are no repair centers near me, so if there’s an easy fix i’d like just fix it myself.
Thanks,
Bob
  1. splintergroupie | Oct 12, 2006 10:41am | #1
    That's how they are supposed to work. More aggessively when spinning, and finer when held down more tightly. I end up finish sanding with 220 with mine(Rupes - not available here), and you can't see any swirl. Just takes a little practice...move it on quickly and off quickly, or start it while after it's on the wood.
    hammer1 | Oct 12, 2006 01:16pm | #2
    It was the nature of ROs for quite a while. PC has addressed the issue. Their newer sanders don't spin up when not in contact. I still hate orbital sanders, though.
    1. DonCanDo | Oct 12, 2006 02:26pm | #3
      Why do you hate them?
      I bought one a while ago after I read an article in FHB that basically said they could take the place of a belt sander and pad sander.  I have NOT found this to be true at all.  My belt sander (4" belt) is lot more aggressive and my pad sander (1/3 sheet) is much easier to control for fine sanding.  I hardly use the ROS.
      I ask why because I'm curious if your experience is like mine.
      -Don
        hammer1 | Oct 12, 2006 06:24pm | #7
        Both my random orbits and orbital pad sanders leave what looks like little spring marks on the wood. The finer the grit, the finer the marks but they are there. The sanders make a lot of fine dust and I have to thoroughly hand sand to remove the marks, so, what's the sense in increasing labor time. I like the RO for prepping paint but I won't use it on good woodwork projects. I should dig out my old Rockwell 505 and sell it, it's polished aluminum, like all hand power tools used to be. I'm pretty good with my beltsanders and will use them for leveling and heavier stock removal. Many high end auto painters use the big right angle PCs for polishing but I prefer the low speed 9" buffers. They are much more forgiving, especially on contours and corners. I'm not fond of inline sanders or jitterbugs either. Too many years in production shops, covered in fine dust for me.Beat it to fit / Paint it to match
  3. LeeLamb | Oct 12, 2006 02:53pm | #4
    Not sure about Rigid, but when one of my Porter Cable OSs spins too much it means the belt needs to be replaced.  I love my orbitals - use them more than all the other sanders combined.
    PaulBinCT | Oct 12, 2006 03:43pm | #5
    Clutch worn out? I had something similar on my DeWalt...
    1. JJV | Oct 12, 2006 07:00pm | #10
      Hey, is that what that is?  I had an old DW 5" ROS and it didn't really spin up until in contact with the wood.  They made a big deal about it.  I replaced that one with a newer model about 4 years ago and this new one sux.  It spins like mad now and I have to keep a much closer eye on how it's working on the surface.
      Thinking about replacing that one too.
      Maybe someday I'll know a little something.
        PaulBinCT | Oct 12, 2006 07:04pm | #11
        Yup, I replaced the brake on my DW ROS and it works like new now... was cheap too.
          IMERC | Oct 12, 2006 07:08pm | #13
          why do that..
          you bought a tool and it should do it's job without you having to do anything other than use it...
            PaulBinCT | Oct 12, 2006 07:14pm | #14
            Ummm..it was 10 years old...
            IMERC | Oct 12, 2006 07:26pm | #16
            seriousely..
            that's no excuse...
        IMERC | Oct 12, 2006 07:06pm | #12
        there's a chance the bearing is shot...
        1. JJV | Oct 12, 2006 07:20pm | #15
          I just saw another posting about the little plastic ring.  I remember that they supplied a spare and I'll give that a whirl.
          No change, and I'm buying the Bosch.  I like their dust filter.
            IMERC | Oct 12, 2006 07:28pm | #17
            had the DW.. long since in the trash...
            got the PC.. like the my Bosch much better..
  5. nikkiwood | Oct 12, 2006 03:45pm | #6
    Have they been doing this from the beginning, or did it just start to happen?
    "It is what we learn after we think we know it all, that counts."
    John Wooden 1910-
    1. Adrian | Oct 12, 2006 06:33pm | #8
      Sounds like the brake is worn out....all of mine (Dewalts and P-C's) have a plastic ring that prevents the sander from revving too high....they are consumables, and have to be replaced. When they aren't working, it's very difficult to land them on a workpiece without scarring.
      I love random orbit sanders; definitely the best all around sander IMO, especailly my air-powered Dynabrades. I can't stand regular orbital sanders.Cabinetmaker/college woodworking instructor. Cape Breton, Nova Scotia.
        PaulBinCT | Oct 12, 2006 06:35pm | #9
        Brake... I knew as I was typing "clutch" that isn't what I meant, good thing I don't make that mistake in the truck ;)
        Thanks Adrian...
      2. BobC | Oct 13, 2006 06:13am | #18
        to all -- yes it definately didn't do this when i first bought it. As Adrian mentions, it's really hard to even touch the wood w/it once it gets spinning w/o seriously scarring.
        question. Are these plastic rings (assuming the Rigid operates similarly to the RO you have) fairly simple to replace?
        BTW, i see you're from Cape Breton. The family (6 of us) drove from SC to meat cove a couple summers ago. What an awesome place.
          IMERC | Oct 13, 2006 06:40am | #19
          yup...
  6. LoneStarGuitar21 | Dec 21, 2019 08:57pm | #20
    Sounds to me like the brake pads aren’t any good. If you Remove the sanding pan off the bottom of the sander there should be a plastic or rubber brake pad. That’s what stops the DA from spinning out of control and they do wear out quite often. It will cause the DA to spend as fast as I can as soon as you turn on the power. The good news is the brake pads are cheap and the fix is pretty easy
  7. foggymtnbreakdown | Nov 29, 2020 09:19pm | #21
    You are right. This is NOT how they are supposed to work. The pad should not spin before the sander is placed on a surface. Ridgid sanders seem to have this problem more than other sanders. I own a Ridgid R2601 that has this problem. Most likely you will have to replace the brake. The brake is a flexible black plastic disk this fits behind the sanding pad and the body of the sander. You can see it without taking anything apart. It almost looks like a black dust shield. It has no moving parts and the brake itself does not move. The brake rubs against the back of the sanding pad to prevent this rotation. The plastic of the brake will wear with time and the spinning will start. I have taken mine to two separate authorized Ridgid repair centers and they just replace the bearing which has not solved the problem. When replacing the brake, I would also replace the bearing because it can cause the spinning problem to increase if the friction inside the bearing is increasing because of wear or because of sawdust getting in the bearing even though the bearing is "sealed." If you replace the bearing, get the EXACT same one. Even a Ridgid replacement bearing will not work properly. The authorized service centers do not put in the "original" kind of bearing. When not placed on a work surface, the bearing should isolate the rotation of the motor from the sanding pad however, there is friction in the bearing from the balls, the grease, any contaminants (like sawdust) and especially the bearing seals. Sooooooo, the brake is there to prevent the spinning of the pad because of this friction that cannot be avoided. Replacement bearings are 32mm (outside radius) by 15mm (inside radius) by 9mm thick. Bearings have different kinds of seals and shields and different kinds of greases and different tolerances. A bearing with the designation 6002RS will not necessarily work. That is what the authorized Rigid repair shops will install. This is OK if your bearing has seized up completely, but you will still get the unwanted rotation when not actually sanding.
  8. Sifi | Sep 27, 2022 08:43am | #22
    Hi, a bit late to follow up, but hopefully useful for anyone else with this problem and doing a search...
    I had the same issue with my Bosch GEX150. It turned out to be the bottom bearing that had seized up. Fairly easy to dismantle, and after a good flush through with ACP50 had it spinning freely again, and the sander is now back to how it should be.
