OSB on the ceiling
loucarabasi | Posted in General Discussion on September 14, 2007 01:09am
Anyone see a problem with me using 3/4inch t&g on my ceiling in the shop? Rafters are 24 oc. it would keep me from having to fur out. Plus 3/4osb’s only 10 bucks a sheet. Will painting keep the smell down too?
Thanks ladies & gentlemen
p.s. ceiling is vaulted
  1. Piffin | Sep 14, 2007 01:24pm | #1
    you mean as a floor for the attic space above?
    That would be fine, but to use 3/4" x 4' x 8' T&G OSB on a ceiling would take about four guys to install it, IMO
    1. DanH | Sep 14, 2007 01:31pm | #2
      No worse than drywall. Use a DW lift or T sticks.Of course, it's not fire rated like DW.
      1. Piffin | Sep 14, 2007 02:02pm | #3
        I have never seen T&G drywall
        1. DanH | Sep 14, 2007 05:17pm | #4
          No, but the OSB can easily be made into non-T&G.
          1. FHB Editor
            JFink | Sep 14, 2007 05:21pm | #5
            yeah...but why? drywall is lighter, cheaper, easier, and more common.Justin Fink - FHB Editorial
            "Everybody wants to know what I’m on...
            What I'm on? I’m on my bike, busting my ### 6 hours a day…
            ...What are you on?"
            - Lance Armstrong
          2. DanH | Sep 14, 2007 05:24pm | #6
            You'd have to ask the OP about that.
          3. Piffin | Sep 15, 2007 01:28am | #11
            "yeah...but why"Because Dan and I have been exercising our mental muscles to wake up by having some sort of little arguement every morning like a chess game. I'm getting to look forward to seeing his responses almost as much as my coffee...;)
      loucarabasi | Sep 14, 2007 11:58pm | #7
      On the ceiling!!! I'll use a DW lift. Drywall we be to flimsy. or do I need a fire rating
      -Lou
      1. BillBrennen | Sep 15, 2007 12:34am | #8
        Lou,If your shop is in a detached garage, and a "hobby" shop not covered by commercial codes, then you do not need the fire rating. If you did, you could screw 5/8" drywall over the surface of the OSB.For the smell, I recommend BIN pigmented shellac as a primer. It may take two coats to seal the surface, as OSB can be thirsty. Topcoat of your choice, or leave in primer. Painting the OSB will do wonders for your light levels, too.Bill
      2. craigf | Sep 15, 2007 12:47am | #9
        Are you worried about the drywall sagging between the joists or is there a need to attach something to the ceiling? 5/8 drywall is used on 24 centers all the time.
      3. Piffin | Sep 15, 2007 01:30am | #12
        "do I need a fire rating"Only your AHJ knows for sure!;)
        1. DanH | Sep 15, 2007 01:43am | #13
          Nah, he doesn't KNOW. But you still have to go with his opinion.
          1. Piffin | Sep 15, 2007 02:14am | #14
            LOL
  2. JTC1 | Sep 15, 2007 01:23am | #10
    Unless you have some special reason for wanting an OSB ceiling - use 5/8" drywall - I think you will be happier in the long run.
    24" oc = no problem with sags, etc.  glue and screw.
    BIL bought a house, with an outbuilding, which the previous owner had used as a wood shop.  It had painted 7/16" OSB on walls and ceiling.  The remaining nooks and crannies in the painted OSB did a great job of dust collection which was missed by his shop's dust collection system.
    Jim
  3. rez | Sep 15, 2007 04:21am | #15
    lou-
     How'd you get $10 a sheet 3/4 inch T&G OSB?
    sobriety is the root cause of dementia.
      IMERC | Sep 15, 2007 06:52am | #17
      don't tell rez nuttin'...
      he'll be on yur dooorstep in a NY minute...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
      loucarabasi | Sep 15, 2007 09:59am | #18
      rez, the big orange box has it for 10.47 (OSB).
      -Lou
      1. rez | Sep 15, 2007 06:41pm | #19
        dang, either I been sleepin' or you got it good in Joisey.
        7/16" osb at $6.47.
  4. dug | Sep 15, 2007 05:28am | #16
    lou,
      I put .032 corragated metal on the ceiling in my shop.  Cheap, easy to hang, reflects light well and does'nt dent to easy if ya accidently smack it with a long board.
      Actually looks pretty good for a shop.
      dug
