Osb over old 1×8 exterior wall sheathing
JBeaudry | Posted in General Discussion on September 9, 2020 08:32pm
Hi I’m new here and I’ve been searching the forum for an answer to my dilemma.
I recently decided to replace my siding that was in pretty bad shape. A lot of the boards were cracking or already broken. When I removed the old siding there is horizontal 1×10 boards that is used for the sheathing. The sheathing isn’t in bad shape for the most part, but there is some cracked boards and a couple that are warping. I can also see some water marks as well. My question is, should I put osb, plywood, or rigid foam over the existing sheathing or just put on a new weather barrier and go from there?
Thanks for any responses
  1. firedudec56 | Sep 09, 2020 10:47pm | #1
    check out zip system/huber engineered wood for insulated sheathing w/"house wrap" - they have a system for 're-sheathing' over existing sheathing - you would have to redo any trim as it won't sit properly with the additional thickness of the sheathing
    https://www.huberwood.com/zip-system/insulated-r-sheathing
    good luck
    1. JBeaudry | Sep 10, 2020 10:40am | #3
      Thanks for the link. I looked at this site before but somehow missed that zip has this product available. I’ll check out some of the videos as well!
    sawdust_steve | Sep 10, 2020 08:32am | #2
    OSB or Zip over the 1x10 would give you better shear strength and a nice flat surface. Tough to give advice on whether it's needed or not when we cant see the condition of what you have.
    Post some photo's and you may get a more meaningful response...
    1. JBeaudry | Sep 10, 2020 10:47am | #4
      Hi Steve, I added a couple photos. Please let me know if those aren’t showing enough of the walls or more photos would be helpful!
    sawdust_steve | Sep 10, 2020 01:30pm | #5
    What type of siding are you going to be installing?
    tfarwell | Sep 11, 2020 10:43pm | #6
    It looks like good quality material to me. I'd make sure it was nailed solidly to the studs and put WRB and siding on it. I think adding foam would be fine as well. Good luck.
  5. firedudec56 | Sep 11, 2020 11:05pm | #7
    the existing sheathing doesn't look "terrible" in the pictures - you could patch in plywood/osb where needed to match the existing, then do the WRB and some foam board to up the insulation value - another thought is to use expansion foam to fill the gaps between the existing sheathing boards then the WRB
    good luck
