Oscillating Multi Tool For Bathtub Caulk Removal
jimmiem | Posted in General Discussion on April 19, 2019 11:59am
I have to remove and replace the caulk at the joint between the bathtub and tile wall.  I have used a utility knife/razor in the past and just bought a plastic Hyde tool.  I’ve also seen info on using an oscillating multi tool.  Some use a wide scraper blade and some use a more pointed triangular caulk/sealant removal blade.
Any experience doing this with a multi tool and which blade?
  1. oldhand | Apr 19, 2019 09:21pm | #1
    No experience with the multitool scraping but I've pondered it. What type of caulk involved is important but I've used a window scraper fitted with single edge razor blade with good results.
    1. jimmiem | Apr 20, 2019 07:30am | #2
      oldhand, Thank you for your reply.
      Silicone caulk. Most of the info I have seen when working around the tub lip is to put down some type of tape to prevent the tool from scraping the porcelain. I can see using the oscillating multitool when removing grout from this joint. The tool manufacturers probably figured they should provide a blade for caulk removal too. I'll probably skip the oscillating multi tool and use a combination of heat, to soften the caulk, and a razor and/or the Hyde tool.
  2. DanH | Apr 20, 2019 08:55am | #3
    Once, about 20 years ago, I found a sort cream that worked great on silicone caulk -- spread it on, wait maybe 20 minutes, and just peel the caulk out. Haven't seen is since, though.
