Out-fitting the next work truck.
CarpentrySpecialist | Posted in Photo Gallery on July 3, 2007 05:33am
Since I had some great help here cutting the noise from the step van that’ll be replacing the old box truck… I thought that posting some pics of the new lay out for tools, lumber and passengers might help someone, sometime out-fit theirs.
I’ll be adding two seats that I saved from a Dodge Intrepid with a blown motor. A friend welded the seat riser for me. Other parts from that Dodge will also go into the van ( Cup holders, Radio, Lights, seat belts and more).
It’s a work in progress that I hope to finish by Fall.
I used metal studs attatched with rivots to secure every thing to the body of the truck. Much cleaner look on the outside than using screws. Some were filled with 2×4 for added strenght.
Best to you and yours, Chris.
Building as thou art paranoid never harmed anyone.
  1. dcarroll3000 | Jul 04, 2007 08:42pm | #1
    I hope you keep the post going. I get a lot of good ideas from this forum. I'm thinking van next time, but I'm afraid the tools rattling would drive me nutty. Do you have a sketch of the final result or just making it work based on past experiences? Best of luck with the new machine.
    -D
    1. CarpentrySpecialist | Jul 05, 2007 08:16am | #3
      A little of both. As it's said, "No battle plan survives a meeting with the enemy." It's important to measure large tools like a table saw when planning a project like this. I started with a CAD drawing then adjusted on the spot when needed.Best to you and yours, Chris.
    user-246028 | Jul 05, 2007 05:43am | #2
    Looks great. I have usually seen the plywood rack laying flat on the floor. I like idea better. way more functional. I just made a rack for my pickup. I don't know how I have managed to go so long with out it.
    Dave
    1. CarpentrySpecialist | Jul 05, 2007 08:20am | #4
      The ply rack is better if it functions like a bookcase and separate the 8-0 lumber from longer stock above that.
      Edited 7/5/2007 1:21 am ET by CarpentrySpecialist
    Huck | Jul 05, 2007 06:00pm | #5
    Great thread - keep us posted on progress.  Love this type of topic!
    "...an open mind is a powerful thing.  The ability to listen to others is invaluable."
    Jim Blodgett
  4. CarpentrySpecialist | Jul 06, 2007 05:27pm | #6
    Here is a drawing that I started with. The 16'-0 storage sacrificed some space in the front door to give the rear roll up door clearance. Necessary since a rating of any trucks cargo area is actually a few inches shorter. Also a 16'-0 board could be really up to 16'-1-1/8" in length. Plus materials tend to shift while driving. So the result is 16'-3-1/2".  Ideally, a 17' or 18' rated truck would be best. Thought I'd mention that if any Carpenters out there were looking to buy a step van or truck.
    Edit; Error in attatchment file, attatchment deleted. New post below.
    Edited 7/7/2007 5:31 am ET by CarpentrySpecialist
    1. dcarroll3000 | Jul 06, 2007 10:48pm | #7
      Could just be me, but I get an error trying to open the .pdf file. Could the caps be causing the issue?-D
      1. dovetail97128 | Jul 06, 2007 11:09pm | #8
        same here."Poor is not the person who has too little, but the person who craves more."...Seneca
      2. CarpentrySpecialist | Jul 07, 2007 12:35pm | #9
        Sorry. I'm no computer guru but the new attatcchment is a wordpad doc. that might be better.Best to you and yours, Chris.
        1. dcarroll3000 | Jul 07, 2007 03:24pm | #10
          No worries, I'm no Bill Gates either. Nice looking setup in the sketch. I dig the built in man fridge. I look forward to seeing it come together.-D
